hello,
i cant seem to find any infomation on RB30 rods other then they have a length of 152.5mm/6.0039"
Now my question is, has anybody used vg30 rods in an rb30? they have similar length (6.071") which would bump up the rod/stroke ratio from 1.79 to 1.81. Obviously pistons would have to be ordered to suit the longer rod length
The reason for this is the availability, cheapness and obviously the quality from using american rods.
Here is the info for a VG30 rod, im wondering if anyone can help me out with the same specs for an RB30 rod
Length-6.071"
Rod Journal-1.967"
B.E width-.817"
https://www.sau.com.au/forums/topic/250743-vg30-rods-in-rb30/
The VG rods are a touch longer, have the same diameter but narrower big end journals and take 22mm piston pins. If you use them you also need to have a piston made which locates the rod in the piston.
If I was you, I'd buy a set of Spool RB30 rods, they drop straight in and are a better rod than any similarly priced rod on the market and even quite a few at up to twice the price. I've used well over 20 sets of the Spool rods and couldn't recommend them enough. They have a little more metal than Eagles in places where it counts and are much better finished than Scat rods. The sizing is spot on which is important if you're assembling it at home and the balance is better than some of the really big names.
As for "American" quality, any rod from America that costs under $200 each most likely comes from China anyway and may have the tunnels given a final rub on a hone in America (probably by an illegal immigrant anyway).
Happy new year.
Greg
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
