Gdya guys I've been playing around with spark timing. Is it ever acceptable for a car to ping, eg: instead of slapping it in 5th at 2g and stomping it I decided to eliminate wind noise etc and pull up the handbrake and let the clutch out on full load. I sarted using this as a test for pinging but thfound that even very close to stock timing (15 degrees) the car wud still ping.
Is this an unfair test? how far can I advance the timing safely? 5 degrees?
cheers
stock they run about 15degress BTDC base timing, mines at around 20 and no pinging and thats even running vortex 95 when im lazy...
my brothers on the other hand has maxed his out, i havent stuck a timing gauge on it but i would assume it has atleast 25degrees of base timing. Still no pinging on that either. It depends on your climate and fuel quality.
ah ok kool, umm whats the best way to test for pinging? basically i chuck it in 5th at about 2g and stomp it. but the thing is the vibration from the car (pulling a high gear) genrally drowns others sounds out, and by the time the vibration seases at about 2- 2.5 grand it doesnt ping. is that ok?
Just wind up all your windows so you can hear just the engine as much as possible then load it up in lower rpms and rev it out like you're doing, 5th is abit overkill, 2nd or 3rd should be fine since its n/a and wont rev out too quick haha.
If you are really worried go to any performance place and ask them to do a dyno power reading, and while they're doing the run stick your head in the engine bay and listen out for it. Probabaly cost you $100 for the run
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
