I was sitting in a hj's drive through this morning and when ever i activated my power windows my car's rev's would dip to almost stalling. I'm wondering if this could be caused by my altinator??
Also if i am driving along at night with headlights and stereo on and i press the brake pedal to stop my stereo will reset sometimes, could these 2 things be related?
My car starts every morning and the battery is only a few months old.
Any help would be much appriciated :P
https://www.sau.com.au/forums/topic/250750-power-question/
Is there anything else about your car that has changed stereo or electrical wise? I have a V35 and I started getting wierd problems like that when I upgraded my sound system. The battery was simply too weak to handle it. I bought an optima yellow top and all of the strange power issues vanished.
I'm no expert, but that's my 2 cents. Hope that helps.
https://www.sau.com.au/forums/topic/250750-power-question/#findComment-4342904
what sort of strage electrical issues where u having? I upgraded my battery just after i put more stereo in so i dont think that that is it, but thanks for your help :P any one else?
https://www.sau.com.au/forums/topic/250750-power-question/#findComment-4342910
Have you got a multimeter? If so start your car and put it on the terminals of the battery It should read between say 13.8 to 14.4ish of the top of my head if it is around that it won't be your alternator....
Maybe a dead plate/ cell in the battery even though it is new... also check what volts the battery has before you start it... Most ECUs wont work properly with less then say 9 to 10 volts
or big drop in amps.. Take it back to the place you bought it and get them to do a load test on it..
Hope that helps.
Edited by 99 GTT
https://www.sau.com.au/forums/topic/250750-power-question/#findComment-4342919
  • 5 weeks later...
  • 4 months later...
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
