Hey every one.
I was reading through some of the topics on here on the VG30 single turbo and they all state that full boost kicks in at 2800-3200rpm.
However mine kicks in above 3500rpm-4000rpm. The car I have is a R32 with the stock RB20.
the mods i have are:
Front mount intercooler
Pod and CAI
VG30 plastic/ceramic wheel ball bearing turbo
3 inch exhaust
AVCR
Stock R32 ECU
I have uploaded a video so you can see the revs vs boost, it’s in bar, it hits about 0.85 bar. The VG30 also is using the standard rb20 turbo's actuator as everyone said the VG30 actuator is no good, hence the reason why it hits around 0.85 bars.
The link is : http://au.youtube.com/watch?v=TqtF4yWCAkU
i just wanted to know whether this is to laggy for the vg30 or is this ok?
Also what could be the reasons why it is so laggy? is there anything i should check to see whether something is restricting it, i also don’t feel much pull, after taking it to a workshop they said it should pull much more harder on boost.
Thanks every one.
niran
https://www.sau.com.au/forums/topic/250752-is-there-a-problem/
Yep, that's pretty much it buddy, smaller displacement motor so you have to rev it more to feed the turbo with exhaust gasses... You could always chuck in an RB25 :P
hey mate, that was my first idea, but then. the info i got where they said full boost was from 2800rpm-3200rpm they where all used in rb20's..
yer but isnt the rb25 a tad smaller then vg30? coz they say the rb25 and vg30 is litrely the same
Rb25 smaller than vg30??? Two different things dude.
Yer a collapsed cat converter can cause slower spool up, simple way to check is to take it off! Get your car on a hoist or some jacks and unbolt it (real easy like 4 bolts) If you can't see through it then your in trouble.
Where there other mods involved to get it spooling that fast on a rb20? Like an exhaust cam gear?
hey man oh really aite my bad.
um yer i will do that today arvo just been spending time with family for new years.
nah there wasnt any cam gear's on them but then agian they had retuned the ecu where mine is just a stock r32, so thats most likley why
thanks for the help niran
A good electronic boost controller will also help the spool up and the consistency of the boost
yer i installed An AVCR last weekend, just getting the hang of it now, so ill keep playing around with it and get it all running sweet hopefully..
Yeah if you dont have the AVC-R setup correctly you can have low boost in some areas etc.
Play around with Duty a bit and then setup the RPM specific settings (Bar Graph).
hey mate, thanks for that yer i shall keep trying with the avcr see if any can get the boost to come on any better.
niran
Edited by niran
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
