Hey every one.
I was reading through some of the topics on here on the VG30 single turbo and they all state that full boost kicks in at 2800-3200rpm.
However mine kicks in above 3500rpm-4000rpm. The car I have is a R32 with the stock RB20.
the mods i have are:
Front mount intercooler
Pod and CAI
VG30 plastic/ceramic wheel ball bearing turbo
3 inch exhaust
AVCR
Stock R32 ECU
I have uploaded a video so you can see the revs vs boost, it’s in bar, it hits about 0.85 bar. The VG30 also is using the standard rb20 turbo's actuator as everyone said the VG30 actuator is no good, hence the reason why it hits around 0.85 bars.
The link is : http://au.youtube.com/watch?v=TqtF4yWCAkU
i just wanted to know whether this is to laggy for the vg30 or is this ok?
Also what could be the reasons why it is so laggy? is there anything i should check to see whether something is restricting it, i also don’t feel much pull, after taking it to a workshop they said it should pull much more harder on boost.
Thanks every one.
niran
https://www.sau.com.au/forums/topic/250752-is-there-a-problem/
Yep, that's pretty much it buddy, smaller displacement motor so you have to rev it more to feed the turbo with exhaust gasses... You could always chuck in an RB25 :P
hey mate, that was my first idea, but then. the info i got where they said full boost was from 2800rpm-3200rpm they where all used in rb20's..
yer but isnt the rb25 a tad smaller then vg30? coz they say the rb25 and vg30 is litrely the same
Rb25 smaller than vg30??? Two different things dude.
Yer a collapsed cat converter can cause slower spool up, simple way to check is to take it off! Get your car on a hoist or some jacks and unbolt it (real easy like 4 bolts) If you can't see through it then your in trouble.
Where there other mods involved to get it spooling that fast on a rb20? Like an exhaust cam gear?
hey man oh really aite my bad.
um yer i will do that today arvo just been spending time with family for new years.
nah there wasnt any cam gear's on them but then agian they had retuned the ecu where mine is just a stock r32, so thats most likley why
thanks for the help niran
A good electronic boost controller will also help the spool up and the consistency of the boost
yer i installed An AVCR last weekend, just getting the hang of it now, so ill keep playing around with it and get it all running sweet hopefully..
Yeah if you dont have the AVC-R setup correctly you can have low boost in some areas etc.
Play around with Duty a bit and then setup the RPM specific settings (Bar Graph).
hey mate, thanks for that yer i shall keep trying with the avcr see if any can get the boost to come on any better.
niran
Edited by niran
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
