Hey every one.
I was reading through some of the topics on here on the VG30 single turbo and they all state that full boost kicks in at 2800-3200rpm.
However mine kicks in above 3500rpm-4000rpm. The car I have is a R32 with the stock RB20.
the mods i have are:
Front mount intercooler
Pod and CAI
VG30 plastic/ceramic wheel ball bearing turbo
3 inch exhaust
AVCR
Stock R32 ECU
I have uploaded a video so you can see the revs vs boost, it’s in bar, it hits about 0.85 bar. The VG30 also is using the standard rb20 turbo's actuator as everyone said the VG30 actuator is no good, hence the reason why it hits around 0.85 bars.
The link is : http://au.youtube.com/watch?v=TqtF4yWCAkU
i just wanted to know whether this is to laggy for the vg30 or is this ok?
Also what could be the reasons why it is so laggy? is there anything i should check to see whether something is restricting it, i also don’t feel much pull, after taking it to a workshop they said it should pull much more harder on boost.
Thanks every one.
niran
https://www.sau.com.au/forums/topic/250752-is-there-a-problem/
  heslo said:
Yep, that's pretty much it buddy, smaller displacement motor so you have to rev it more to feed the turbo with exhaust gasses... You could always chuck in an RB25 :P
hey mate, that was my first idea, but then. the info i got where they said full boost was from 2800rpm-3200rpm they where all used in rb20's..
yer but isnt the rb25 a tad smaller then vg30? coz they say the rb25 and vg30 is litrely the same
Rb25 smaller than vg30??? Two different things dude.
Yer a collapsed cat converter can cause slower spool up, simple way to check is to take it off! Get your car on a hoist or some jacks and unbolt it (real easy like 4 bolts) If you can't see through it then your in trouble.
Where there other mods involved to get it spooling that fast on a rb20? Like an exhaust cam gear?
hey man oh really aite my bad.
um yer i will do that today arvo just been spending time with family for new years.
nah there wasnt any cam gear's on them but then agian they had retuned the ecu where mine is just a stock r32, so thats most likley why
thanks for the help niran
  and3_3 said:
A good electronic boost controller will also help the spool up and the consistency of the boost
yer i installed An AVCR last weekend, just getting the hang of it now, so ill keep playing around with it and get it all running sweet hopefully..
  femno said:
Yeah if you dont have the AVC-R setup correctly you can have low boost in some areas etc.
Play around with Duty a bit and then setup the RPM specific settings (Bar Graph).
hey mate, thanks for that yer i shall keep trying with the avcr see if any can get the boost to come on any better.
niran
Edited by niran
