Brand New 17" Koyo Drift Teks 8"fronts 9"rears
You can probably break everything and any point that's true. But with the "precautions" of building the entire engine and everything around it and with a solid tune I wouldn't expect that to happen right of the bat. 😛
You don’t need to use full throttle all the time to break these blocks, 500kw at the wheels in more then enough to break them even with an occasional squirt. Hell I’ve seen them break under 400kw
A work around is to install the R35 card style AFM/MAF on the cold side of the intercooler piping and the BOV on the hot side piping. Works well, also you can combat the revs dropping by adding a bit more ignition timing on the idle ignition timing table to slow the rate of RPM drop. -
Understood. If you dont have a ridiculous limit, Tune, T's and P's are in check, and arent bashing it all the time and doing the due deligence for maintenance(inc oil analysis) then its pretty safe. 100% agree, let your right food control it to some extent.
So these external kits with the machined block for remote solenoid mount will only work on a NEO head and RB30 or RB26 bottom end For an R33 head on a 26 bottom end the remote vct kit is to resolve RB26 manifold adaptor plates etc IF you try to use the remote VCT on an RB30 or RB26 bottom end with an R33 head then you can starve the cam journal??? I have one of these kits from bits I had years ago before plans changed I don't understand how that tracks with this video https://youtu.be/RuPiI22Mplk?feature=shared This looks like I can run the v termite vct kit to feed the VCT on an R33 head on an RB26 bottom end?!?!? Lol.... don't v have these problems on RB20s
