Hey people ive got left over stuff from my old R33 ,
had a bit of a clean up.Got one complete set of standard front and rear springs/shocks.They were fine from no oil leaks just the boots need replacing do to wear,( they came off a car with 90,000ks) just upgraded for lower look, ans also have a pair of FRONT only Heavier duty shock with lowered springs.They lower the car by about 30mm<in good condition and working order.
These a good for spares or for someone waiting to get there coil overs in if there old shocks are stuffed.
All up pick up the whole lot for $100 or bring two cases of mexico's finest beer, that is coronas and there yours.
Just throw me a PM or can be contacted on 0413337889,These are located on the sunshine coast QLD,I can post them at your cost.
Thanks
Chris
Edited by R334door
https://www.sau.com.au/forums/topic/250793-for-sale/
hey dude where are you, interested for getting off defect. thanks.
Oh sorry about that i forgot to add they are in QLD on the sunshine coast, BUT i can post at your cost,i sent whole set of coil overs to adelaide a while back and i think it was around $30 to $40 depending on your postcode.
https://www.sau.com.au/forums/topic/250793-for-sale/#findComment-4343344
  • 1 month later...
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
