ok im trying to cut labour costs on servicing my skyline so thought id give it a crack
any tips or things i should beware of before attemting this..im quite a noob so i dont wana stuff it up i read a thread about this guy on the soarer central forum that drained his transmission fluid thinkin it was his engine oil and stuffed up his car big time and i aint stupid but i dont wana be that sort of a noob so just taking precautions thats all
https://www.sau.com.au/forums/topic/250798-r33-service/
just make sure you have a filter strap and the correct oil filter before you drain the oil.
if it's your only car, you dont want to run new oil with the old filter because you couldn't get it off or it was wrong..
and hand tighten your oil filter means AS TIGHT as you can get it by hand.. no strap.
https://www.sau.com.au/forums/topic/250798-r33-service/#findComment-4343528
and when your doing it check all your coolant hoses, belts, boost hoses etc so you catch any problems developing before they become problems.
have fun..
also dont get under your car if it is only on a trolley jack. put it on stands so it cant fall on you..
https://www.sau.com.au/forums/topic/250798-r33-service/#findComment-4343531
Yeah I have to check the coolant hoses bcuz as in my other thread the car is overheating but it needs an oil change desperatly, I'm definantly getting a new filter along with penrite semi synthetic oil but what Is a filter strap? Sorry for sounding like such a noob boys LOL
https://www.sau.com.au/forums/topic/250798-r33-service/#findComment-4343646
a filter strap is the tool you use to loosen the oil filter. because they are usually too tight to undo by hand.
if you are lucky you will get it by hand.
also when you fit the new filter, smear some engine oil onto the rubber o ring on the filter then spin it on..
i only have to remove my breather hose on the rocker covers and flip it over to get my plugs out. (rb20det though)
https://www.sau.com.au/forums/topic/250798-r33-service/#findComment-4345927
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
