hey got booked in my 32 looking at selling it was wonderin if any interest...
its a 1992 32 gtst stock as a rock except for mushroom pod
car will be sold as is unreged
before i sell it i will be putting a brand new fround mount and a 2 1/2 inch full turbo back exhaust on.
it has a GTR bonnet turbo timer 18inch GMAX wheels with dish :D
g4 adjustable coilovers pretty much brand new few months
cant think of anything else atm... i had a microtech lt-12s i was gonna put in but im selling that seperate unless someone wanted it added in the price.. i also have alot of spare 32 parts or addons such as a dual stage HKS boost controller
the car comes un reged but i have personalised plates which i would be happy to sell with the car for extra (NIS532) silver on black
if there is any interest give me a text or a call on 0447619249 .. serious buyers only no tyre kickers.
https://www.sau.com.au/forums/topic/250818-r32-gts-t/
    • Once the belt slips it can very easily cause a cascade that encourages more belt slip. Check the pulleys carefully and see if the grooves have cupped. If it has it's time to replace the pulleys. If the rubber has glazed you also need to replace it. Shouldn't be shiny. From the factory there's a lot of exposed fibers(?) on a v-belt that will go away as it's broken in but some should still remain visible without sticking out significantly like a new belt. I went through this on my dad's Camry recently. It would keep slipping even after setting the tension higher, only solution was a new belt.
    • Belt polished and/or pulley(s) glazed. Rub pulleys with sandpaper, replace belt.
    • I've also got a quick jack. I would never get under my car again without using it.  While it might be quicker to use a jack and stands, it is such a quality of life improvement that I wouldn't have it any other way now.  How much slower the quick jack is to setup will be based on your circumstances. Can you leave the jack rails on each side of the garage? Can you leave the hydraulic lines attached? etc.  If you can drive the car into the garage and simply push the jacking rail thingos under the car into place, it is super quick to setup and use. But if you have to pull the pump unit out of storage, attach the hydraulic lines, wheel out the lifting rail thingos.... yeah takes a bit of time. Having said that, I would still prefer that to using a jack and stands lol.
    • Sydney Tools have them for ~$3400. More than the Quick Lifts but these seem better. https://sydneytools.com.au/product/quickjack-7000tl208240v-5175642-7000lb-110220v-portable-light-duty-truck-and-passenger-car-lift-system
