20/1/09 Wtf!111! Cactus Jacks Is Back!
IT’S BACK! It’s been a long time since we have had a night out at the infamous Cactus Jacks.
Lets make this a big dinner meet SAU, I expect plently of new face’s to come along, as well as some old face’s.
If everyone could RSVP for yourself and any guests by the 13th (one week prior) so I can give them plenty of notice to make sure we can get tables near each other.
What the event is:
Tuesday Night Dinner - Cactus Jacks
Loganholme Hyperdome
Cnr Pacific Hwy & Bryants Road
Loganholme, 4129
Near the cinemas. Parking is available in the multi-level car park
Date:
Tuesday 20th January 2009
Time:
7pm Booking
Cost:
As much or as little you wish to spend. Sub $20 meals
Requirements:
*You must RSVP as I need to make a booking
RSVP:
1) Nismo_Boy (Josh)
2) Bunta (Andy)
3) impact_blue (Anna)
4) Johno
5) BLiNKsTaR (Michelle)
6) RRB20ASH (Ashleigh)
7) R33S2 (Terry)
8) shanef (Shane)
9) Fineline (Noel)
10) mrbenno (Benno)
11) jase-r34 (Jason) + 1
12) Strik3r (Gervase) + 1
13) Hell Fire (Adam)
14) shnaped_second (Milhouse)
15) 666DAN (Dan) + 1
16) Mushroom (Troy)
17) Kuntie + 2
18) Ed G (Ed)
19) Traditimeour (Jeremy) + 1
20) V8skylineMAN (Jason) + 1
21) Wagamama (Tim) + 1
22) Charly (James)
23) TJ_R33 (Tim) + 1
24) Rhinorebel + 1
25) 83CKS (Becky)
26) grex32 (James) + 1
27) rb25kateosaurus (Kate) + 1
28) Beelzebub89
29) hojak (Michael) + 1
30) choyda
31) Elite Racing (Dan) + 1
32) 32chick (Madeleine) + 1
33) brad_gtr (Brad) + 1
https://www.sau.com.au/forums/topic/250828-20109-wtf111-cactus-jacks-is-back/
  • Replies 127
Posted Images
hahaha....I feel it only fitting that a copy of the vid appear here...sadly, I don't have it anymore. Hence, i will just say SLLLAYYYEEERRRRR...though few will know the meaning.
I have a private copy. It's under lock and key.
I know where it is!!!!! :blink:
What the event is:
Loganholme, 4129
Date:
Time:
7pm Booking
Cost:
Requirements:
RSVP:
1) Me
IN <3
IN <3
OMGWTFBBQEDDDDDIIIIIIEEEEEEEEEEEHHHHHHHHHHH!
I really want to go now, I think I'll make it if I leave on my scootah of fury today! tops speed of 50kph is awesome........................... no, no it isnt...........
I miss you Ed... and Cy... even though I am not officially "old school", I looked up to you guys when I arrived on the scene.
And Josh, I am doing everything humanly possible to get out of the night shift I am supposed to be working on the 20th!!!
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
