20/1/09 Wtf!111! Cactus Jacks Is Back!
  • Replies 127
Posted Images
Where I was working in the CBD made me cut my hair. So much blonde is gone, each cut was like burning a $50 note.
dun be sad josh. All teh bread is gone too. It has all been gon for qwite sum time.
I am actually quite looking foward to tonight.
Ps josh: I think I can hear a machine calling your name. A machine..... that you need to RAGE against. Fight the power.
Edited by Charly
you know what, i am also really looking forward to tonite... its been so long since i have seen, well, most of you!
picsorban of shenanagins tonight bishes.
Bahahaha nothing to report Ro, although we did get a good shot of ranga's gheyness.....check out SAUQLD
Becks - you left early without visiting table No.2!!! Till next time :(
Mmm chilli in my belly....
sorry to tell you but she was sitting next to me which was 4 people to your left :(
AHH YES... I remember asking ppl if that was her!! but no one knew.
are you the dude which might be going to the cruise and was giving me sh*t about park spaces for 100+ cars?? LOL.
Becks - you left early without visiting table No.2!!! Till next time :ermm:
Awww I really wanted to meet you too, But didn't know if you were there lol
was becks there? i didnt see her :/
Yeah, i was just down from you.. :cool: Was going to come say a random hi, but got a bit shy :D Next time for sure :thumbsup:
It was great meeting everyone i did get to meet! :wave:
Edited by 83CKS
Yeah, i was just down from you.. :D Was going to come say a random hi, but got a bit shy :ermm: Next time for sure :thumbsup:
It was great meeting everyone i did get to meet! :cool:
Yeah we had Becks on our table, but our table was way cooler especially the end where I was (with the help of Josh & James <3 ). It's only fair that the R34's are on the same table anyway, we're way more 1337 than you other guys :wave:
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
