Help Help Help 48kw
shotter
 Share
Ok i took my car in to get dynoed and tuned today and it was going fine and making about 180kw. Then during a run it made a loud popping noise and started backfiring. then it kept backfiring as you back off the throttle. and The car only made 48KW. Basically we tryed a lot of things to find the problem. the adj valve timing solinoid wasn't working for a little while, then it started working again. The AFM decided to go to 5.1V and the car wouldn't start. After some searching we found a cracked solder track. Fixed that and the car started but still no power. Tryed different AFM. Does anyone have any idea's or have been thought this problem before?
  • Replies 124
Posted Images
The car makes boost. Sorry i should have said that. It makes and holds boost fine. And the fuel pressure raises and holds fine too. I checked all the intercooler pipes myself and they all were tight.
Still sounds like a boost leak problem. Maybe split grommet or blown gasket somewhere. Do a boost leak check--quick, easy, and next to free, just to eliminate that as a potential problem. Maybe that's not it, but that's where I'd start.
could be a collapsed catalytic converter, saw similar thing happen to an evo on a dyno run, he hit 70kw though
its making boost thought, even if there is a leak, its still getting 12psi or whatever hes running in the plenum, should be making more than 48kw.
the only powerloss from a boost leak should be the drop in effeciency as the turbos spinning hard to make the required boost at the plenum, due to the leaking air somewhere else. unless theres something im missing?
The air ratio's are around a normal level. So nothing bad going on there. We thought it could be a timing problem when the adj valve timing stopped working. So we pulled the front cove off and pulled the trigger wheel off and noticed that the key that sits inside the cam and also the trigger wheel had snapped off. But we didn't think that was a huge problem because we checked the timing and it was ok. The one think that did pop out was the PCV hose and grommet. The grommet split. So we were able to put a bigger rubber hose in the hole and slide the PCV valve into it. It doesn't sound like it's leaking. But i dont know if it's venting pressure into the top of the crank case. And i guess it could even be the std ecu. it's not logging any fault codes but i dont know if that is causing it. Another idea i had and i really dont wanna think about this one is could i of melted a piston?
It shouldnt be any internal damage i dont think.
I suppose it doesnt make any funny noises when you drive/boost?
Can you post up the last dyno run before it "blew"? It could still be a boost leak somewhere, but the turbo would be working harder to "make" 12 psi or whatever you boost. What was the peak boost you had?
Just a wild and noob suggestion - have you reset the ecu? since you said youre running the stock ecu, and if thats the case, able to swap ecu's or even the CAS with a working one off your mate?
You say that its boosting ok, does that mean you can "feel"the power as before? or you feel the turbo boosting but you dont go anywhere, is that the case?
Whats the timing set to?
I dont have any dyno sheets. and it is still on the dyno. You can hear the exhaust note change at about 3000 rpm, it just goes really flat.
We have pulled the ecu out and tryed running the car with another r33 ECU but the car wouldn't turn off with that one connected. So we decided not to do a run with that connected. And it does make a ticking / rubbing noise at idle. which went away when we loosend off the bolts on the timing wheel /trigger wheel / destributor... whatever you call it.
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
