Help Help Help 48kw
shotter
 Share
  • Replies 124
Posted Images
The BOV was tightened right up and works fine. It hasn't got a gates timing belt. The rubbing noise went away as soon as you loosened the front bolts. It ide's fine and revs at idle with no problem (except for it backfiring when you take your foot off and the revs fall back to idle. No blue smoke at all. What 3 cam timing marks are you talking about? One option i thought is to pull the cam out and get a CAS that has the key in it. and get a cam that has the opposite key. Just so i know thats fine. But im guessing thats alot of work if it's not going to fix the problem.
But if the timing was ligned up at the 0 mark on the crank with a timing light wouldn't that say that the CAS is working fine and the cam is in the right spot? And how do you know exactly what point to put the CAS in?
The workshop is very unlikely to lend you their tools and hoist to do the work for yourself, what do they get out of it? Plus their are insurance issues they would need to think about by letting someone in to work under a hoist that doesn't work there. Bit different if the engine was out and on a stand, but not on whole car up on a a hoist
Seriously dude, rather than just get everyone to list every possible thing it could be, just pick the car up, thank the workshop for their time and "effort" and take your car somewhere else. You will probably find out that it is something very simple and take not much time to fix, or it will be something major and take a bit of work, either way at least you will know what is wrong with it. If the new workshop can't find the problem then you haven't lost anything except maybe a hundred bucks for trailer hire and a bit of your time.
That and your car will look like a fully sik tokyo drifter on a trailer lol
I have already worked on the car while it has been sitting on the dyno. and i have taken my car to another workshop before and they were hopeless. This workshop seams to be good just a really weird and hard to find cause.
Im starting to wonder.... What would have caused the PCV valve to blow out during a dyno run? Because all these problems started to happen after the car popped we found the gromet had split and the PCV valve was sitting out a bit.
The actuator arm is working, you can see it moving. We have chacked the actuator and it's working fine. And the motor isn't std, it has been rebuilt in the past with forged pistons.
If the dyno is in use, then the proplem should be sourced, we use our dyno as a diagnostic tool, not a tuning tool. unless the dyno is a VAIN then there should be enough equipment to diag the proplem there and then.
Other than that it mean's the equipment isnt being used correctly.
Edited by EFI Performance
Not if that's the timing at idle. It's supposed to be 15BTDC. If it's only 0 (TDC), then the spark is firing 15 degrees too late right across the range. Considering that at full noise, the timing might be supposed to be 10BTDC, then it's actually firing 5ATDC. That's into the power stroke - no wonder it can't make power!
The key on the exhaust cam controls where (at what angular relationship) the CAS mounts. Without the key, the CAS can only be in one position for the engine to run - any other position, and it just won't start.
So if the cam marks are where they should be, The belt hasn't jumped a tooth and if the timing light is showing the right angle then this would rule out the cam? Or would i still need to replace the cam for one with a key and the CAS for one with a key?
Car sitting on a dyno is not the same as car being on a hoist. End of the day it is up to them if they want the potential legal problems it could pose if something went wrong. I'm with Drag and GTST, try the ignitor and the CAT, forget about the cam for now, do the easy quick stuff first!
The loom for the coils plugs into the ignitor. Should be a silver metal thing with finns on it and 4 screw holes. On a 32gtr it sits on top of the valley cover at the back of the engine, dunno bout 33 though, and 34 have the ignitor built into the coils
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
