  • Replies 124
OMFG ITS FIXED!!!!! Well it's back to normal anyway. The workshop found the cause of the problem.
The NEG lead from the battery. I think before i bought the car it was replaced by the owner but they didn't do a very good job, because the wire just fell out of the connector. So that would explane why it was playing up in the past too. So the workshop replaced the wire and the very 1st run it was back up over 200kw.
Yep I would like to know the bill too. After all the suggestions and help from members, one of them really stood out that he never tried from the get go...
GO TO A NEW WORKSHOP!
Probably would have had this fixed ages ago.
I doubt another workshop would have found it easy. It's not a usual thing to pop the boot open and pull on the NEG cable. And if i did take it to another workshop i would have 2 bills to pay for and not one. I dont know how much it's going to cost yet because they are still tuning it. And where did 6 weeks come from?
i may have exagerated the 6 week part but nun the less, battery terminals / connections is one of the first things they should have checked.
how long does it take to grab the terminals and twist them and then grab the wires and tug them? 5 seconds tops.
these are the simple obvios things that should allways be checked first.
if they took this long im sure it was just a flook that they found the prob at all.
Shotter - You can doubt all you want but I guess you will never know???
Just because your battery is in the boot doesn't make it special. Even on a basic service they check your battery. And if doing work on electricals or even playing around with them they "should" have disconnected the battery first to eliminate popping fuses... or getting a nasty shock from a faulty coil ignitor holding thousands of volts.
Come to think of it this workshop sounds ace, I may take my ride on lawnmower there for a dyno run, I rekon it would top your 48kW! Especially in Rabbit mode!! lolz
Edited by Dirk Diggler
Well i just got told the cost....... F*#KING $2196
$900 for workshop time
$1100 for dyno time
and the rest covered parts used.
So not happy.
Now im not saying they didn't spend alot of time on the car. Hell i spent 2 days on it. (what a waste) And they kept saying oh we will look after you and it wont cost all that much. I dont know about you but $2196 is alot in my books. It would have been really nice for them to say "look we found and fixed the problem and the bill is around the $1000 mark, Would you still like us to tune it" My answer would have been "NO $1000 is more than i thought it would cost all up. BYE. I guess it goes to show that it doesn't matter how friendly they are or how much you think they are doing you a favour and will look after you. They are ALWAYS after money and will bend you over. So now my car will probably have to sit in there workshop for the next month till i can get the money to pay for it...
It might not be obvious for that problem - I had a mate with a very similar problem in an R33 - ended up being that the timing was completely out, but surely wouldn't someone notice!?! I for one always check the battery connections in my cars, if only for buildup of contaminants usually.
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
