Wow, what a pain in the ass!
The last battery earthing problem I came across was harder to diagnose than this but it wasn't confused with cam sensor problems and a forum thread! next time you have a problem make sure you state your vehicle specs at the beginning of the thread instead of drip feeding them throughout the pages. The workshop in question has overcharged you for the services performed without doubt. That said.... I cannot tell how you handled yourself or how they did. It seems to me that you have kept a level head throughout this ordeal and i feel for you. This type of problem should be treated as a valuable learning experience for the workshop and they should have charged you much less for the hassle of them learning how to go back to basics to diagnose a problem properly. Most of the suggestions made were good ones but few have the skills to work this out in a short time. A good quality jumper lead from the negative battery terminal to the block or a voltmeter in the same position would have sorted it out quick smart.... easy for me to say from the comfort of my keyboard!!
Dead set it is hard to find good workshops... I am a auto elec and find it very hard to refer people to workshops because incompetence and overcharging is taught form day 1 in the industry! That is a harsh generalization that is sad but true.
Dabro makes a good point or two... but like you has not taken the time to provide his name , car or other details in his avatar that make it easier and more comfortable for others to join in and make intelligent comment!( or talk shit...).
All the best
Danny
  • Replies 124
Im not denying the workshop didn't spend alot of time on the car finding the problem. Because i know they did spend alot of time. The thing that pissed me up the wall was that they kept saying the bill wouldn't be all that much but wouldn't give me a $ amount until the work was all done. Apparently the justification for the dyno time cost is to cover the use of the dyno and the operator. What a load of crap.... And i wont be taking my car back for the simple fact they didn't tell me the bill was going to be that huge.
All the best
Fair enough, avatar updated.
Onto my fourth Skyline, Currently building an oldschool style GTS25 sedan with RB30DET. Cant seem to shake them, sell one only to start all over again :-)
Engine Builder/machinist by trade. 13 years. 7 Automotive, 5 Aviation.
Do everything my self and like it that way.
Perrin
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
