ok i brought a second hand nismo 2-way diff centre..
so today went to install it and have come into a pickle.i went to put the r200 stock gear around the 2way and the bolts that where on the stock gear do not fit in the 2way they are too big..
why is this?
what are my options now?
only thing i can think of is to buy new gears.
thanks for your help
https://www.sau.com.au/forums/topic/250859-nismo-2-way-diff-install-problem/
IIRC, the difference between an R33 and R32 R200 centre, is the R33 has larger diameter bolts... maybe you had a 33 diff in there to start with..
But yes, when you buy the Nismo 2-way kit new it comes with lots of stuff like new crown wheel bolts, new gasket, flanges, oil etc.
its going into a r32 gts-t so s13 diffs are the same r200.....and no the bolts are off my stock r32 not r33. all i have to do is drill the holes bigger now iam worried about the shafts will the stock r200 shatfs fit into the nismo 2-way?
thanks for the comments guys
test them out before drilling anything it'll take 5 minutes an if they dont fit sell the unit an buy one to suit your car or buy the other gear to make the diff fit in your car
no they will not. you need the matching nismo stub axles. thats if its a nismo one,
unless you have an open (non lsd) r200 where you have to swap the stub axels left to right
could be out of a early dr30. as far as im aware all the diffs hr31 onwards used 12mm bolts. exceps the silvias. and when you get a nismo diff it comes with spacers for the bolts. the opposite of your problem.
what was it out of?
i have done a centr swap in my 240/260z long nose r200 housing, the early Z diffs (fuji/subaru as are the later sklines) use M10 crownwheel bolts, i bought a used tomei r32 gtr centre off ebay a 2 way mech lsd.
one thing i found that the diff shop really wasnt keen on doing the swap, but aggreed to give it a look over.
after no response i went there paid 40$ for nothing and did the swap myself.
turns out the 32 gtr/r33 used an M13 bolt (yes M13???? go figure) so what i had to do was machine some bush's spacer @ 13.1 od 10.0 id x 11mm long for the 10 bolts.
as far as side/half shafts i had another circlip groove cut on the drivers side shaft to match the clip in the 32 centre, speced of the gear mesh and lash adj (happened to use the supplied shims that came with the centre and it was spot on lash wise)
from what youre saying it sounds as though you may have either 10mm ?? holes in your new centre yes you could just drill out to suit, but do so carefully.
after my install i was/am able to use the std 32/early 33 shafts (29 splines) they plug/play no problems, but i can still use the old uni joint hafshafts because i had the extra groove cut in.
i have done a pretty visual show of what i had done on vicZcar forum if you are interested
cheers nat0
cheers nat0
that was a bit confusing but i get what you mean so yea i will just drill the holes bigger not problem
and with the sharfts i need 2 small ones as the stock ones, the other 1 is longer so i need two short ones then it will fit hopefully...
what was it out of?
Nismo diffs do not use "Nismo" stub axles, they use two standard ones (short).
R32 & S13 have the same bolt size (I know as I'm running S13 gears on my R32 Nismo 2-way centre).
My local diff guy was more than happy to set my diff up and I just swapped the housings.
Edited by bubba
yes, the "nismo shafts" that are supplied when you buy the centre are standard evan though they are differnt lengths????? must be only the new ones that have 30 spline shafts.....
as with all the diffs its just a matter parts swapping till you get it correct.
My Nismo 2-way for 32gtst used two of the short shafts, they were genuine nissan items supplied in the kit.
yeah thats what i need..actuly only one small stock shaft then i can bolt this thing all on.
If you don't know what you're doing then it's best to get a diff place to install the centre into housing and shim accordingly. (don't think you can re-use the pinion bearings but I may be wrong)
i'd be getting a fresh set of bearings put in it if you've pulled it out an had it sitting where they can get shit in them. not worth the trouble of having to do it again as soon as you start driving it
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
