Time has come to sell.
Car:
  • 1994 Black R33 GTS25 Type-S
  • Manual 5 speed
History:
  • In 2004 by Special Vehicle Imports (QLD) with 50,000km. In the time I've owned it I have traveled approximately 10,000km per year. It has just clicked over 100,000 km and has had the timing belt and water pump replaced. It was serviced by Chapman and Chapmans every 10,000km and I change the oil, oil filter and inspect the spark plugs myself every 5,000 km in between.
Wheel/Suspension/Brakes:
  • Nismo LMGT4 forged monoblock rims 17x8.5 with Federal 595RS tyres (95% tread)
  • Whiteline springs with modified circlip height adjustable Bilstein shocks (Sydneykid spec)
  • Whiteline fixed front and adjustable rear swaybars
  • Whiteline adjustable front and rear camber bushes
  • Whiteline adjustable front castor bushes
  • Whiteline pineapples
  • Nismo front strut brace with master cylinder stopper
  • R33 GTR rear strut brace
  • Locked hicas
  • R32 DBA slotted rotors and calipers (rebuilt) front with Hawk ultimate brake pads
  • R32 stock rotors and calipers rear (rebuilt) with Hawk ultimate brake pads
  • ADR approved front and rear braided brake lines with Motul RBF600 fluid
Drivetrain:
  • R33 GTR clutch
Power:
  • Coby extractors with HPC (heat proof coating), 2.5" high flow metal cat and a standard R33 GTR exhaust
  • Apexi SAFC-II (Black version) tuned by Matt Spry
Cosmetics:
  • R34 GTR bucket seats
  • Stealth rear wing
  • Nismo tinted side indicators
  • Tinted windows
Extras:
  • CD Headunit
  • Pioneer 6.5" front speakers and Pioneer 6x9" rear speakers in a custom MDF shelf
  • Australian approved 3+1 immobilisation point $1000 aftermarket alarm system (installed by Chris Rogers, will disclose if buyer is serious)
That's most of what I can remember at this stage, they are the main mods and probably a few more little ones that I have forgotten.
As you can see it's quite a reasonably modded R33 GTS and is perfect for someone (especially P-Platers) who are keen on getting serious with the car in the future. I also have a set of Sparco Racing rims 17x8 if interested for a reduced cost. It currently has the Type-M front bar, however the stock one can be put back on. Also have Type-M side skirts and rear pods (white) which can be included if required.
Price wise, I will let it go for $14-15,000 right now. However I am aware of the current market and am flexible on pricing. I have retained a majority of the car's standard parts and will let it go for significantly lower price with a stock setup without all the good bits (ball park $8000).
Not separating for parts at this stage, but will separate to sell the car.
Contact: 0403112979 or PM (Eugene)
https://www.sau.com.au/forums/topic/250871-1994-r33-gts25-type-s-non-turbo/
thanks for the comments and free bump.
it certainly is a good package for someone new to performance cars and cars in general to start out. remember the package can be customised to suit budget!
  • 1 month later...
any figures on how much power was gained from the safc? i have been thinking about getting one but wasnt sure if it was worth it.
$7000 grand cash thats all i can afford and yuu have a deal i will ring yuu up and find were yur located if $7000 sounds k reply Edited by wrxstippp
Why did you quote me?
gained about 5-10kW, wasn't a power tune though. basically to clean up air fuel ratios
If you want it stock I might consider it, otherwise you're about $7-8K short mate.
considering i asked for a ball park $8K for a stock setup i think you will pretty much get that. if you are serious and really have the cash to go then give me a call and we can work something out - i may throw in the brakes and sparcos.
stock suspension, stock seats, basic sound system, take the safc out, stock swaybars, no strut braces, stock extractors, etc.
  • 3 weeks later...
if you don't sell it with the 34GTR seats i have first dibs on them :/
hahaha... everyone has asked me about them!
car will get a once over in the coming weeks. a service as well as getting the rear pods and side skirts fitted and painted.
  • 3 weeks later...
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
