hey guys
putting my motor setup for sale complete or the way it is
here we have a un open rb25det low comp on 2 clys
rb30e block out of drift 31 car was turbo mint condition
now u could buy both like they are for 700 or complete rb30det all built ready for turbo and injection
new head gasket timing belt and oil pump for 1200
but has to sell this week make offers guys,
i have all the info to build this and part numbers,
pm me be quick
located in sa
i only want to sell complete not block only ,
yes rb30 if put together will have the mods done, we just built one in r33 run like a dream, and before made same setup as my motor with gt3540 turbo made 320kws on 16psi. mad power buy it complete, or in parts and build it ur way i have all the part numbers u need to build it, offers guys needs to go this week highbid will get it by next friday cheers
So is the RB30 an NA bottom end, or was it the factory turbo bottom end?
When you say complete built RB30DET, is that with new bearings or anything else done to the bottom end?
mate can you please contact me in regards to this 25 block you have advertised i have the cash and have been awaiting a reply i have pm'd you my number already
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
