problem been discussed a lot on sau, its common on all r32's to need a blip of the throttle to stop it stalling.
Unfortunately no one has found a solution to this problem :D
When i put in a brand new heavy duty battery it would crank and idle with no throttle, but over the weeks it went back to its stalling.
A possibly solution is to clean the cold air regulator which lets in more air on cold starts. Perhaps this could be getting stuck and causing the stalling;
http://www.skylinesaustralia.com/forums/Ai...amp;hl=cold+air
Also doesnt hurt to clean the AAC valve too;
http://www.skylinesaustralia.com/forums/Di...html&hl=aac
Let us know how it goes ;)
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4345651
ive cleaned the AAC and AFM , there is a noticeable difference after cleaning it. if you haven't do so , i highly suggest you to do that first.
wanna do mine? <3 :)
How is your battery? You might have a weak battery, try recharging overnight and see how it goes.
When i put in a brand new battery it cranked once and jumped to life, but now its gone away :)
Also, when i first purchased the car it had no cold-start issues, it gradually happened after driving the car, so something must have worn out/clogged up during that time..
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4347171
is yours RB20?
hmm battery seems fine , then again it came with the car ,ill check that next.
and yea it gradually happened
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4347204
notice something funny, if i prime the fuel pump before cracking the engine, it most likely gonna have a hard cold start (rev below 700rpm)
HOWEVER, if i start the key straight away without waiting, the car actually starts at first go (rev stays at 7-800rpm bout 1-2 sec and its back to normal 1100-1200 rpm)
but still a tiny bit hesitation but no where near as bad as before.
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4347894
Mine starts strangely in the morning also, turn the key and it fires up nicely. Revs drop to almost a stall, tap the throttle and up it goes to about 2 grand for a while. Strange yes! Done anything about it, no! :D
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4351294
Here's a video of my starting which i recorded over a year ago. Sounds similar to yours AdMan
I always have to blip the throttle when starting or it stalls, i tend to blip the throttle into any other car i jump into because of this haha
Im putting in cleaned gtr injectors soon and getting a tune, will see if it will fix the problem.
Also, not sure if it helps, but after i installed a gtr fuel pump, the cold start actually got worse..ho hum
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4351533
Definately clean your cold air regulator. It's a bit of a bitch to get to but it worked for me.
Had the same cold start problem as you. Turns out the regulator was stuck open, pulled it out and cleaned it and now it starts nicely - no throttle needed.
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4354358
Hi there, I have had this issue for years now, I had the injectors cleaned, new temp sensor, cleaned the AAC valve and really didn't see that much of difference. One thing I did change which helped a lot was one of the Fuses that goes to the ECU, this made the most noticeable difference but didn't cure the issue. Does anyone have pics of what the Cold Air Reg looks like on a 33? Just want to have a look because it might be worth a crack.
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4354565
^^what he said..
which fuse are you referring to?
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4354568
Check out this thread for some pics of the cold air reg: http://www.skylinesaustralia.com/forums/Fi...ob-t174735.html
Seems like it's even harder to get at than in the RB20...
https://www.sau.com.au/forums/topic/250904-hard-cold-start/#findComment-4355945
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
