stagea's and ruts dont mix . anyone else looked under the back of a RS four S and noticed the hicas motor points straight down and is about 4 inches lower than the diff . stupid really . really stupid when you look at a skyline one and all the motor and stuff points backwards from the rack and does not affect ground clearance at all . yeah i took it up a 4wd track to get to lock katrine . the track is not very bad at all . no mud or big rocks just quite undulating and fine if you drive on the high spots . i only managed to scrape the muffler once . nothing else hit the ground but yeah the hicas got the electric motor ripped off it and the rack bent backwards till it hit the fuel tank and the wheels did what they wanted . kicked it forward and tied it to the diff mounts with some fence wire and managed to get home .
have found a perfectly good series 2 hicas rack for 50 bucksk so ill slap that in and if it doesnt work it will be turned into a lock bar with the aid of some washers
whats the go with the electronics behind the hicas when people have fitted a lock bar ? other than removing the light on the dash . like pull out the fuses and relays or leave them ?
get some pics up later when i pull it all apart
https://www.sau.com.au/forums/topic/250919-hicas-light-comes-on/
