I got the head off our 98' Stagea yesterday to replace blown head gasket (80k). While the head is off I thought its a good time to give the ports a tickle. Are people match porting out to gasket sizes on both inlet and ex. or just make sure gases are not hitting a shoulder? Are people removing lump in exhaust? Also are people replacing head bolts??
Edited by skidkid
https://www.sau.com.au/forums/topic/250932-head-off-rb25t/
I found the R33 spec factory manifold gaskets pretty well matched already, but checked and touched up both sides where necessary.
That lump in the exhaust port I smoothed out the sharp leading edge considerably and blended them in to the overall port shape.
The short radius in each port, leading onto the seat was where I spent a fair bit of time. Ex-factory that really was an abrupt edge and needed work.
Overall, not much material taken out but quite a bit of finishing work that the factory doesn't do. I'll have an idea later this month if I'm happy with my work :D
New head bolts not essential, but aren't expensive and should be replaced if the engine will see a bit of work.
https://www.sau.com.au/forums/topic/250932-head-off-rb25t/#findComment-4345566
