  • Replies 41
Biatches please.. :P
Gradenko - mine are all between 150 and 155 with the exception of number three which is 130, which was considered low. All of yours down at this level don't sound too good to me..
Go the conversion! :P
Adam - thats my plan too.. :)
The thing is I can blame the low readings on an uncharged battery and unlubruicated cylinder walls. Compression test results can be random like that.
I'll see if Steve thinks the dyno reading tomorrow is about average or too low.
Adam, Not necessarily true, alot of people don't keep cranking them, they stop at 4 cranks, if there is any major difference then you know the compression is low, so actually readings can be misleading, it is the variation in readings that is important.
Originally posted by adam 32
compression test aside, 350ml of oil has come from somewhere...
350mL of oil in vapour after 20L of oil has passed through it (4 oil changes). Could that be classed as normal? Macka has that filter on his breather, does he find a layer of oil coating his bonnet lining?
The catch can mod is damn useful. All this oil would be lining the inside of my intercooler and clogging the idle solenoid otherwise.
Pretty much the first time its been checked, yeah.
Just got a call from Danny, it pulled 280rwhp (shootout) after tuning on SST's rollers with no sign of detonation. The front facing plenum mod is a success! :). 280rwhp isn't anthing special, but its about all a 5 knob s-afc is going to let us safely extract.
Originally posted by zanda
maybe get a real catch can without coke residue in it! :)
Careful, dont knock his coke bottle, he's awfully proud of it.
Half full eh, so when a you going to go the twin coke bottle mod?
lol @ zanda
deesh, the coke bottle rocks! Its the kind of quality engineering we've come to expect from Coca Cola Corp. Afterall, if it can hold concrete etching coke for months at end, whats a little luke warm oil? :)
Twin coke bottle mod is coming. The hose attaching the left and right breathers together has a crack in it, so I may as well run new piping from the left breather to a bottle of its own :)
BTW, test drove the car today and its insanity peppers. Modified plenum mod is highly reconmended for all you fmic'ers.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
