hey guys.
i just put a rb25 into my r32 got it running and the one welsh plug i thought i screwed up, started pissing out coolant,
so the reason i had troubles getting it in was because of the coolant like which goes into the thermostat, ive uploaded pics, and i need to know if it screws out or if you pop it out? or what can be done, the other welsh plug i tried getting out with plenum on and ive pushed it to the left so i need to get wire in there to flick it back across, damn copper,
any info would be good,
Cheers JV
https://www.sau.com.au/forums/topic/250943-help-welsh-plug-rb25/
hey guys.
Cheers JV
Have fun, I recoat them when i build motors and that particular one is a pain in the ass!
Nissan used some hard core locking epoxy compound so the method to do it is to head up the block all around it till its real warm then use a set of locking pliers on it and slowly work it side to side till its loose then start puling while rotating it... if you dont have that sort of patients (and somtimes the buggers just dont let go) get a new one from nissan and go wild on the one in there to get it out.
  • 8 months later...
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
