  • 3 weeks later...
saw this on youtube, must say that they do some pretty impressive work!
good work guys!
I wonder what would happen if Rigoli built a light datsun for his RB30 ? or Martook? those datsuns weigh 1000kgs yeah ?
1200's are more like 720/730kg. Perfect weight to start off with. Rigoli had a tubbed 1200 ute at an expo 2 weeks ago that looked FJ powered (bonnet wasnt up enough to really see at the time).
yeah rigoli's ute was fiat powered, he has had that for years no ???
Im talkin a rb30 powered datto like RIPS
pretty sure anothy with vl god from mautouks racing will braek it very soon
Rigoli's built that engine in their car. Its always at their fabrication shop next door.
Rigoli's VL has no weight reduction in it at all either or it didnt last time i was sitting in it.
1200's used a 4cly engine, whereas the zed's used a 6, which saves a lot of fabrication putting the engine in.
this thread reminds me of my dato 1600 i built 10yrs ago with an fj20t
what a beast. cheap fun except 4 traction
i had a 180b sss with a FJ20det in it as well. had around 260hp at wheels. traction is a interesting topic with those saggy rear ends hey ? :)
  • 3 weeks later...
The 240z race weight was 1277.5kg as it was REALLY over built when they did the rear end, lots of thick heavy box section in the rear.
The new car which is getting the 240z motor is quite a bit lighter so hopefully we'll get the times down some more and keep the Aussie's (who are obviously on the way) at bay :P
Rob
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
