I have a set of Work Emotion Kai rims for sale. They are bronze and in excellent condition.
5 x 114.3
18" by 9.5, +20 offset all round. Perfect for that tuff stance!
Rims have Bridgestone RE01's on them but all have very little tread (unroadworthy).
Located in Melbourne.
If interested please PM me.
$2200 firm.
Edited by drftr32
Tyres are 225/45/18.
At least you could always buy new tyres.
These rims are light weight genuine jap rims with awesome specs, you cant replace that.
If you can find another set of genuine jap wheels with the same specs that comes with good tyres for less then $1999, i'd suggest you'd buy that.
$1999 firm people.
Look at the market, do the maths = bargain!
I thought these were sold!!!!! i offered $2200 for these and got knocked back :P
No offer was ever made? You asked for a quote on shipping, i replied, you replied with information about a stuff up you had encountered with your brembo brakes being from an r32 gtr... ending the message with "i'll be in contact very very soon". That was on the 5th. No contact has been made since? If you still want them, i guess its a win for you as i've dropped the price to $2k. If your still keen PM me and i'll send you bank account details. First in with the funds will take them.
ok - i'm keen! just waiting to get my car back from the workshop so i can trial fit them to my 35.. what suburb are you in?
I'm in Hallam (south eastern suburb). Let me know when you would like to trail fit them as soon as you get your car back.
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
