jst having to make up some custom cooler piping for my setup, and was wondering if anyone had a good argument for where i should place my bov. atm im slightly confused as my mate has his bov jst after the turbo before the cooler, he does this because he belives it does a better job of protecting the turbo from spining backwards......but if this is true why do you see nissan placing there bov's after the cooler, is that because there plumbing colder air back to the turbo...........or does it not make a difference where she goes.....any ideas guys.. :D
https://www.sau.com.au/forums/topic/250973-bov-before-or-after-fmic/
Ive always run them as close to the throtle body as possible ie 6-8 inches away.
and as for being "better" for the turbo to place the BOV close to the turbo, mmm cant really see how its going to make it better.
what does matter is plumbing wasted air back into the intake pipe after the AFM.
cheers
Turbos NEVER spin backwards. Load of shit. What sort of blow off valve is it? If its aftermarket you might want to hide it down near the cooler so cops dont give you trouble unless you feel the need to show it off. I prefer plumback blow off valves personally and would put it in the stock nissan position unless you have a front facing plenum etc.
Closer to the throttle body you've got the air flowing one direction only, if you put it at the other end you end up with air moving back and forward through the IC, possibly having your colder air in the system reabsorb some of the heat as the pressure drops and becomes less dense.
Suppose with a larger IC it will hold a pretty fair capacity, but keep in mind at 3000 RPM your engine is sucking in over 0.075m3 a sec (150 CFMish), so whatever air sits in the IC will be gone pretty quickly once you get back on throttle. May not matter so much until you're chasing big power/response but if you're going to do it once, closer to the throttle body is likely to do better.
Edited by Hell Fire
ok so after taking all this info in, i've decided that i am placing my BOV before the cooler only because it makes it alot easier to plumb it back. the way i have riged it up is the bov well be in an enclosed box where the air filter is housed keeping under bonnet temps out, also the cooler and air filter piping to the turbo have been wrapped in heat resitant tape, hopefully this well help keep the air going to the turbo fairly dense.... also im sticking with my stock bov , it does a good job , sounds good and is legal too.
Sell the bov.
Many cars out there (street/rally/grip/drift) that run without them and have no reliability issues.
The response gained when running no bov out weighs any driveability or if it concerns you emission negatives.
I've ran 20psi for a good 30k and not one issue.
Prior I had run 100,000km's on the std ceramic turbo @ 1bar and again no issues.
^^ please dont start the 'gain' rubbish.
End of the day, the stock ECU expects a BOV to be there. Emissions also required it.
Using cars that are not street registered and working within the confines of the law are not valid examples
I have a power fc tuned with the blow off valve off as the intake pipe im using at the moment doesnt have an inlet for the plumback. The car runs the same as with the stock ecu in (well for me anyway). It almost stalls when you press the clutch after being in gear at high revs etc. Its also a lot more jerky on gear changes. I have learned to deal with it but it deffinately is different the way the cars drives and ill be putting the bov back on as soon as i can be bothered to make up a new intake pipe.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
