Now that i have ur attention. I have a fully rebuilt Rb25 most of which has been modifed excluding the standard cams. im looking to achieve that 500hp figure. Most of everything has been dun to the motor, i kno its vague, but has any1 hit the 500 hp mark atw? what camshafts are adviseable if i don't want to modify anything else (ie cylinder head clearance machining, up-rated valve springs, special retainers, solid lifter kit)?
If it does hit 500hp atw ... u all will definitely be detailed
thanks
https://www.sau.com.au/forums/topic/25101-rb25-makes-500hp/
  • Replies 64
Originally posted by INASNT
i think he means 500 engine hp
Originally posted by GT 1
...has any1 hit the 500 hp mark atw?
...If it does hit 500hp atw ... u all will definitely be detailed...
Which part was complicated about 500 hp atw, inasnt? I think that means at the wheels, mate :P
hahahaha
https://www.sau.com.au/forums/topic/25101-rb25-makes-500hp/#findComment-533428
rofl
By nuts I meant... "dammmn im still having fun with only 270rwhp, double that would be out of this world"
Instead of those floor mats that say "Get in, sit down, shut up and hangon" you would need "Get in, sit down, shut up and i hope you brought a spare pair of undies"
https://www.sau.com.au/forums/topic/25101-rb25-makes-500hp/#findComment-533534
the highest you can go up to i have been informed is 264 degrees of rotation, before you have to machine the head, get new lifters and valve springs
tomei cams don't make a 264 they only make 260 and 270 or 272 (don't quote me on this though)
hks have 256, 264
whats been mentioned to me is that the 264 cams will be enough to get ya 500hp, anything more then 264 is really for darg machines with 700+ hp :P
adrian :P
https://www.sau.com.au/forums/topic/25101-rb25-makes-500hp/#findComment-533614
i they pon cams or the other ones that tomei make?
coz i have read direct from the tomei website that for rb25det there is no listing of a 264 only 270 anyways if your correct then tomei and hks both have 264 :P
adrian :P
https://www.sau.com.au/forums/topic/25101-rb25-makes-500hp/#findComment-533651
