  • Replies 45
Yepp, I've got one too :P
Build date was 26 September 1995 - Wooohooo, it's almost it's birthday ;)
Has Series 2 motor
Series 2 rear wing
Series 2 boot latch doova
ABS
Drivers side air bag
But I blew up the 1995 ECU :P Big bummer... So now I'm running a 1993 ECU.. And yepp, I felt a definate drop in power between the 2 ECU's :)
https://www.sau.com.au/forums/topic/25102-33-series-15/#findComment-533635
Originally posted by Ronin 09
*how do you blow up the ECU??!?!
*what is the series 2 latch doodah?
LOL, you hook up a shift light to the ECU while forgetting to turn the ignition off and forget to unplug the ECU from the harness !!
Not a good thing... You hear crackle crackle pop...... then the smell of smoke.
And like my electronics teacher told me years ago, transistors are made out of smoke, cause once you let the smoke out they don't work anymore :P
The series 2 boot latch doova's are made from a machined alloy of some sort, instead of having the clear plastic epoxy over them.
J
https://www.sau.com.au/forums/topic/25102-33-series-15/#findComment-533867
sweet.. the only thing i'm confused about is when i bought the car the dude gave me the comliance sheet showing everything that was done when it origianlly came and it said that it was built early-mid 1994
i was a bit cranky as the point of sale was that it was a 1995 car but he said its a 95 model just built in 94
didn't the s1 come with an airbag too?
i have one i just didnt think that it was only available in the 1.5 and then the dual in s2
https://www.sau.com.au/forums/topic/25102-33-series-15/#findComment-534336
How can anyone forget the sexy sexy series 1 velour interior in the series 1.5? :) I often thought that if I bought a series 2 R33, I would track down a series 1 interior to put in!
Jay, you should have used frying your ECU as an excuse to get a Powerfc :)
https://www.sau.com.au/forums/topic/25102-33-series-15/#findComment-534356
I think the later series 1's has the silver badge with the open grille rather than red s with slat grille. Mine has the former, there was a time I thought it was an aftermarket grille but now I think it was just the later series 1's.
Series 2 has the badge on the bonnet instead of grille.
https://www.sau.com.au/forums/topic/25102-33-series-15/#findComment-534409
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
