Oil, Oil Filter and spark plugs is what i would do. check your gearbox and diff fluids but they should be fine as long as they are at the correct level. Changing them out however would give you piece of mind as you would at least know what you have in them then.
https://www.sau.com.au/forums/topic/251053-serivce-kind/#findComment-4347224
Damn bro 29000 definabtly oil and filter change, does the engine sound ok on cold starts as in mornings? My r33 wasn't sounding the best, like knocking bcuz the oil became too thick so that when it started it couldn't suck up the oil quick enough, may be different on an r34
https://www.sau.com.au/forums/topic/251053-serivce-kind/#findComment-4350462
sounds really loud when starting the car in the morning but only for the first ten seconds i guess thats normal
https://www.sau.com.au/forums/topic/251053-serivce-kind/#findComment-4351322
i finally serviced my car last Saturday i did the following service and im having issues with 3rd and 4th gear it crunch's every now and then, the funny thing is it didn't have this problem before the service, what could it be?
engine= ROYAL PURPLE 10W-40
gearbox= REDLINE LIGHTWEIGHT SHOCK PROOF
diff= REDLINE 75W-90 HIGH PERFORMANCE GEAR OIL
also changed spark plugs and oil filter
Edited by Turbotonic
https://www.sau.com.au/forums/topic/251053-serivce-kind/#findComment-4377453
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
