well usually you tell the clutch is going cause it will slip lots
for example put your car in 4th when ur doing a low speed so that ur engine is doing pretty low revs and then hold ur foot down, if it accelerates slowly but normally then its probably ok but if ur car revs and you dont really speed up then ur clutch is probbly gone
I dont understand the noise ur describing however
like a ratched as in lots of successive clicks? how quickly do they follow each other?
could be a problem elsewhere or a gearbox or throwout bearing problem
https://www.sau.com.au/forums/topic/251056-clutch/#findComment-4347221
Yep, worn clutch plate will see slipping under load like Boostin said.
If there's an issue with another portion of the clutch system then the symptoms will be different.
A worn pedal box can make a racket, a worn slave cylinder can also make a racket.
Give us a bit more of an idea of what's going on.
https://www.sau.com.au/forums/topic/251056-clutch/#findComment-4347892
well it makes that always just as i take my foot of the clutch, so its louder racket when i take my foot off the clutch normally during reversing
any ideas would be appreciated thanks all
https://www.sau.com.au/forums/topic/251056-clutch/#findComment-4348918
That's an interesting one.
Would need to hear the sound but for the sake of it inspect the pedal box (the assemnbly that the pedal is connected to) and check the slave cylinder for leaks.
What 'kind' of sound is it? A squeek? A rattle? a loud bang? a deeper thud?
If you can't pinpoint it at the pedal box or the slave cylinder then you'll probably have to get it inspected at the very least.
https://www.sau.com.au/forums/topic/251056-clutch/#findComment-4349901
throwout bearing sounds like if it happens when ur foots off the clutch
mine does it and ive only had a new clutch/throwout bearing in there for about 5000km's
im not sure why the throwout bearings wear or whatever they do so quick
do have to say however mines not like what ur describing but yours could be considerably more worn then mine or perhaps incorrectly fitted?
do you know if/when its had a clutch changed and if they replaced the throwout bearing?
https://www.sau.com.au/forums/topic/251056-clutch/#findComment-4363012
im not sure i had the car imported but its only done 30.000KM im guessing the clutch is still the first from birth
https://www.sau.com.au/forums/topic/251056-clutch/#findComment-4365885
more then likely
mine had a stock clutch in it when i got it. you should know if they are stock as they are rather soft and have a wide pressure point..... (or whatever its called im having a mental blank)
but if u run your car and press the clutch and the noise goes away then it could be your throwout bearing
https://www.sau.com.au/forums/topic/251056-clutch/#findComment-4367931
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
