Made a new thread for this - have better photo's and a new price (and can't edit old thread):
Up for sale is my 1998 Nissan Skyline R34 GTT white turbo coupe.
Its tiptronic auto (with steering wheel controls), has 99,470kms, Xenon headlights (big $$$ option), dual airbags, ABS, Traction control (switchable), power everything, climate control, LSD - all electrics are in excellent working order.
I have owned the car for almost a year, before that its was just imported from Japan and was completely stock as a rock. I have spent a lot of dollars modifying it to my taste - it has only been modified for about 5000kms of its 99,470kms, so its still a VERY healthy car.
Professional Mods as follows:
Front Mount Intercooler installed by Grotto Engineering
Walbro 500hp high flow fuel pump installed by Race Solutions at Penrith.
Apexi SAFC NEO purchased new and tuned by Hitman at Penrith.
Full 3" stainless HKS exhaust from turbo back.
Boost controller set to 11psi (never been boosted over this and has only been running 11psi for 5000kms, stock before that).
Pod, CAI and heat box.
Brand new Splitfire Coilpacks - Croydon Racing
Greddy turbo timer
Top of the range 3 point Mongoose Alarm with tow and wheel sensors installed by Platinum PI.
Pioneer double DIN 6 stacker CD with pioneer splits.
Blue LED mod to dash lights.
Eyelids.
Car has been methodically serviced with the best oils and parts - 5,000km oil and filter changes, 100,000km service complete which included new water pump, thermostat, timing belt, bearings, crank seal, cam seal, all new ancillary belts, power steering fluid change (over $1000 service). Then had auto trans serviced with new oil and new spark plugs installed and new O2 sensor. Car has original Japanese log books and owners manual.
Mechanical condition is excellent and motor pressure checked very healthy with pressure even across all cylinders. Nothing else to spend. This has not been a 17 year old thrash mobile (I'm 28) and drive it very maturely.
Car is tuned at 200rwkw at 11psi. Very quick and with the tune I am getting 12.2L/100km around town and on a recent highway trip to Newcastle got 9.9L/100km so very economical too.
Above mods add up to thousands and have all receipts. Tyres at 70%, brake pads have plenty left, rego till March 2009.
Asking $18,000, now $16, 500.
Post, PM or can call/text on 0413 0412 10 (if I don't answer, please leave a message and I will call you back ASAP). Please no time wasters or test pilots.
Thanks,
Tony
https://www.sau.com.au/forums/topic/251060-fs-r34-gtt-white-turbo-coupe-sydney/
Hey man, cars looking awesome - did my mate Matt manage to get in touch with you about this?
Hi Troy - yes he's coming to have a look today (you need to clear PM's too).
    • Hey, it's me! Though honestly, if I had 20M in my bank account tomorrow, I would not want to be rid of my car all of the sudden - Which makes me think this is money stuff, not "I actually hate car" stuff. I'd probably double down and buy even more trinkets and fun things for it. If this is not you, then sell it cheaper. It will sell at a certain price after all.
    • This is the LCA mount reloctaion kit. Self explanatory in its description. https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=62&_fid=1e812d392&_ss=c These are the alloy subframe bush inserts that I am using. I like them. https://au.gktech.com/products/rear-subframe-slip-in-collars?_pos=29&_fid=1e812d392&_ss=c Alternatively, if you have original and shitty bushes, you might consider outright replacement with poly. https://au.gktech.com/products/polyurethane-rear-subframe-bushes?_pos=28&_fid=1e812d392&_ss=c I would also higly recommend that you look into adjustable RUCAs and tension rods, so you can sort out the camber and bump steer behaviour, especially if the car will be any more than ~15mm lower than stock. I would also highly recommend the GKTech FUCAs, although you really should do some research and learning on the subjetc of R32 FUCAs before making any decisions. All of this will be criticaly difficult to get through a TÜV inspection too, if that happens to be relevant to you. Note that if you do install the relocation kit, you will absolutely have to replace the associated bushes with spherical joints (you can read all about that on the product page) or upgrade the LCAs also.
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
