G'day guys, I was looking to reduce the amount of body roll in my r33, and was wondering if cutting the springs would be sufficient (until I can afford sum coilovers of course). Is there any way of doing it at home? (ie: without special tools)?
how much should I cut off?
and do you cut it off the top of the spring or bottom?
any help is much appreciated, cheers
https://www.sau.com.au/forums/topic/251067-cutting-springs-on-r33/
ah theres som good advice, cheers nightsky. think thats is my best bet. Im aware that it puts heapsa stuf out of whack, I think the desperation of not being able to cut lap of a tight roundabout without bottoming out got the betta of me haha.
im off to shop 4 sum swaybars !!
so u guys rekon whiteline do good stuff?
Firstly dont cut your springs, this is something uneducated bogans do to their commonwhores.
Secondly all it will do is lower the ride height and put all of your spring rates out of whack.
If you want less body roll buy a set of sway bars like Whiteline. They will reduce body roll alot until you can afford your coilovers.
also get your self front and rear strut brace. i had that installed in my R33 and did notice a big differance in handling. a set of front and rear strut brace you could find for under $300
but ye no no on chopping springs
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
