Ok seems like a funny question but i am looking at converting my stock ( and clapped out ) GTR diff from 2 way to and reconditioned 1 way.
Does anyone have any information on how to do this please, short of this i will be sending my diff to Terry at award to do.
https://www.sau.com.au/forums/topic/251076-diff-conversion/
  • 3 weeks later...
yeh i would have thought with a 2way in the front of the gtr it would understeer, i'm pretty sure its common practice to have a 1 way in the front, but yeh i dont think you can convert them, just have to buy the right center
https://www.sau.com.au/forums/topic/251076-diff-conversion/#findComment-4386715
Prey sure hes talking about the rear... The stock rear diff is a 2 way mechanical and the stock front is just an open diff. Dont think you can even get 2 way front diff's for the gtr...
https://www.sau.com.au/forums/topic/251076-diff-conversion/#findComment-4390275
some aftermarket diffs come with a key that activates the plates under load. the key is shaped like a triangle in a 1 way and like a diamond in a 2 way. I am unfamiliar with the stock centre but it must have a key of some sort. if you were to replace it with a less aggressive triangle it will lock the diff slower and more predictable under acceleration and not at all under braking.
here isa very good link about different mechanical lsds. there are pictures of the different keys down the bottom of the page :)
cheers
https://www.sau.com.au/forums/topic/251076-diff-conversion/#findComment-4392464
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
