Hey
I have an RB25DET head for sale
specs:
- RB25DET head
- Inlet manifold with injectors
- RB25DE cams (more lift than DET cams)
- Been tested and is in good condition, no warpage, valves vac up good
no Throttle body, coil packs, exhaust manifold or turbo
can also supply loom and ecu from an RB25DET to anyone interested
$650
RB30 Short motor
- Series 2 NA block
- done 116,000km
- inc Pistons, rods, crank all assembled
- AC Compressor attached too
In good condition. Been checked and was given the all clear.
Can either bolt the head straight on and go from there, or pull apart bottom end and build it up.
$200
Buy them together $800
or make me a reasonable offer.
Cheers
Dave
https://www.sau.com.au/forums/topic/25109-rb25det-head-rb30-block/
thinking of holding on to it now.... had someone promise me the world to come take the lot off my hands... havent heard back.
so i think i should pull my finger out and build it myself!
No mate.
I have a guy in Brisbane who contacted me tonite and is still keen on the whole package... which suits me best.
me paying for postage... i dont think so.
  • 6 months later...
Sorry for the slight hijack, but I sold an RB25/30 complete a few months back... listed in here and on ebay... it was amazing the amount of people who would give a low offer and then expect me to pay shipping. Cheeky buggers.
Erm... yes, I'll pay for you to have it even cheaper. Geez.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
