thanks for the kind words gerry!
that grill is sick. tying not to advertise that mine is a turbo though. going for kinda sleeper kinda not.
socrates, would suit your car to a tee wouldn't it??
update:
bought some adjustable LCAs and they will work but still need another 50mm of length. so... ny mate who's been helping me with the car knows someone with a cnc machine and he gunna make up longer versions of the adjustment tubes for us. that's happening monday. the hybrid datsun/silvia adjustable castor arms are getting done then too. even then the castor arms wont be a straight fit to the LCAs. so a bracket will be made up which bolts to the LCAs and the the castor arms will bolt to that.
when everything is actually in place and working, i will make a step by step recipe on how to do it. firstly ill say that if you want to do this, please know in mind that it isnt cheap or very straight forward!
they pay off is gunna be better handling (hopefully), better brake upgrade possibilities, parts availability, extra lock with big tyres, and fitment. we've done some calculations and the wheel will be flush with the guard :-)
ill let you know how everything goes.
until those things are fabricated there isnt too much to do at the moment. so i fitted my stepper gauges from the silvia into the datto. i removed the instrument surround and tech screwed them in to the very left. they are hanging from the top in front of the clock (that's never worked) and the super high-tech warning display. the wires were fed through a gap above the instrument panel and down behind the dash. nice and hidden and stealth like. looks great!
note: grab an angle grinder and cut the excess of the screws that stick out. as they will foul on the dash when you're trying to get the instrument surround back in. and you will not have to cut a hole for the wires to go though, it'll just bend up enough without even any force.
the fuel system is next. will probably chuck a Bosch 044 below the tank. unsure if the standard fuel lines have the flow we need but this motor isnt too insane so will just have to see. there's plenty of room in the stone guard to add a braided line if need be.
till next week, have a good one :-)
thank man. yea found that one a while back. so awesome how much work he's put into it!
the LCAs he's made from scratch is exactly what i just bought but mine are adjustable. and where he's left the thread is exactly the stage that im up to! lol.
on another note, the fuel pump arrived today! installing tomorrow :)
  • 9 months later...
boy oh boy have i been broke for ages! finally got back into some crane work and thus back on the coin :-)
the project has been at a stand still for months and months so now i just have to finish everything i started basically. i've done everything i could with what i've got and what skills i possess. now i just have to throw some money at a few things. and thankfully only a few things!
as soon as my mate helping me with the suspention side of things comes back from the mines, this thing should be back on all 4 paws and i can show you guys how we went with the s13 front end conversion. there's a bit to it but should have quite a few gains and adjustable everything.
had nothing to do after work so spent a total of $60 and 5 mins of my time to wrap my dump pipe. when this motor was in my s13, cabin temps got pretty rediculous at times so hopefully this makes things more comfortable. makes shit look pretty neat too.
seems legit?
as usual, to be continued :)
how is everyone?
yea i love my 20! it loves limiter bashing at 8k and spitting flames out the screamer :-) made 260hp at the rears in my silvia on a shit tune/ stock ECU ect @15psi.
jason was kind enough to hand over his Mine's stage 1 ECU for this motor. if i wind up the boost to max which is 21psi and a better ECU again, i should see 300-odd at the treads. but i also like reliablility and 15 is enough to have fun with. trust me, the boost comes on pretty hard.
braaap!
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
