thanks for the kind words gerry!
that grill is sick. tying not to advertise that mine is a turbo though. going for kinda sleeper kinda not.
socrates, would suit your car to a tee wouldn't it??
update:
bought some adjustable LCAs and they will work but still need another 50mm of length. so... ny mate who's been helping me with the car knows someone with a cnc machine and he gunna make up longer versions of the adjustment tubes for us. that's happening monday. the hybrid datsun/silvia adjustable castor arms are getting done then too. even then the castor arms wont be a straight fit to the LCAs. so a bracket will be made up which bolts to the LCAs and the the castor arms will bolt to that.
when everything is actually in place and working, i will make a step by step recipe on how to do it. firstly ill say that if you want to do this, please know in mind that it isnt cheap or very straight forward!
they pay off is gunna be better handling (hopefully), better brake upgrade possibilities, parts availability, extra lock with big tyres, and fitment. we've done some calculations and the wheel will be flush with the guard :-)
ill let you know how everything goes.
until those things are fabricated there isnt too much to do at the moment. so i fitted my stepper gauges from the silvia into the datto. i removed the instrument surround and tech screwed them in to the very left. they are hanging from the top in front of the clock (that's never worked) and the super high-tech warning display. the wires were fed through a gap above the instrument panel and down behind the dash. nice and hidden and stealth like. looks great!
note: grab an angle grinder and cut the excess of the screws that stick out. as they will foul on the dash when you're trying to get the instrument surround back in. and you will not have to cut a hole for the wires to go though, it'll just bend up enough without even any force.
the fuel system is next. will probably chuck a Bosch 044 below the tank. unsure if the standard fuel lines have the flow we need but this motor isnt too insane so will just have to see. there's plenty of room in the stone guard to add a braided line if need be.
till next week, have a good one :-)
thank man. yea found that one a while back. so awesome how much work he's put into it!
the LCAs he's made from scratch is exactly what i just bought but mine are adjustable. and where he's left the thread is exactly the stage that im up to! lol.
on another note, the fuel pump arrived today! installing tomorrow :)
  • 9 months later...
boy oh boy have i been broke for ages! finally got back into some crane work and thus back on the coin :-)
the project has been at a stand still for months and months so now i just have to finish everything i started basically. i've done everything i could with what i've got and what skills i possess. now i just have to throw some money at a few things. and thankfully only a few things!
as soon as my mate helping me with the suspention side of things comes back from the mines, this thing should be back on all 4 paws and i can show you guys how we went with the s13 front end conversion. there's a bit to it but should have quite a few gains and adjustable everything.
had nothing to do after work so spent a total of $60 and 5 mins of my time to wrap my dump pipe. when this motor was in my s13, cabin temps got pretty rediculous at times so hopefully this makes things more comfortable. makes shit look pretty neat too.
seems legit?
as usual, to be continued :)
how is everyone?
yea i love my 20! it loves limiter bashing at 8k and spitting flames out the screamer :-) made 260hp at the rears in my silvia on a shit tune/ stock ECU ect @15psi.
jason was kind enough to hand over his Mine's stage 1 ECU for this motor. if i wind up the boost to max which is 21psi and a better ECU again, i should see 300-odd at the treads. but i also like reliablility and 15 is enough to have fun with. trust me, the boost comes on pretty hard.
braaap!
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
