hi guys,
there are rumours going around the trap that the r35gtr requires a full rebuild @ 100,000km & apparently this is a 15k major service - could this be true?
i have also heard from a workshop here in sydney that they are having a lot of gearbox issues with striping gears (1 particular in the US has changed his gearbox 5 times) - & apparently considering a recall but this would run nissan into the ground
here is a clip of a 10.5 pass where this black gtr strips 1st gear OUCH (refer to 2nd clip):
http://www.gtrblog.com/index.php/2009/01/0...f-the--1?blog=4
regards,
https://www.sau.com.au/forums/topic/251111-are-these-rumours-true/
I imagine it makes no difference to nissan if people are braking gearboxes after getting a chunk more power out of it then drag racing them. If you up the power things will break, thats a given and should be accepted. That GTR that ran a 10.6 is making worlds more power then stock so a gear box breakage was expected.
Over 100 launches using the Nissan GT-R's now infamous launch control, with approximately 30 of those resulting in a sub-10 second ET, took it's toll.
somehow i dont think thats what nissan allowed for when designing the box...
As for the engine thing - the answer is no body knows. It has something to do with the plamsa bores but I can't remember exactly what.
But then it's 100,000km's. I wish my R34 GTR engine would last that long before it needs a +$15K re-build!
Pretty sure if you read through this forum there will plenty of information regarding the gearbox issues, the car that strips 1st in the video has been widely publicised as having in excess of 600hp, 700nm and running consistent 10 sec 1/4s. It may be worth your time to have a read through some topics with things in the title like "R35 gearbox" to get some info in this.
yes it was the plasma bores that i also heard
i agree with ur comment about the 15k rebuild...i guess its like an rb26 running 295awkw and hoping to get 100000km
(this is what the r35 achieved on crd's dyno)
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
