Hey guys
Picked up my r33 gtr a couple of days ago and have discovered that the ecu looks like it has been chipped by garage saurus in Japan, does anyone know exactly what they change when saurus chip their ecu's?, i have also noticed that both 02 sensors have been disconnected, would there be any reason for this?
I still seem to get decent fuel economy, got 200kms out of half a tank ofr 98, and i wasnt driving it easy either for some of the time, so that seems pretty decent to me.
I was a bit worried when i 1st saw the garage saurus sitcker on the ecu as i dont have a clue what could have been changed on it and if its safe or not, but the old owner had the car for 9years and never had a problem with it, also seems to be running rather rich as the bumper gets carbon stained.
Any help would be great.
Cheers
Jason
best to get the car on dyno to check if afr's are safe, i use blitz chipped ecu on my 32R and it has speed limiter (180km/h), boost limiter removed and rev limiter set higher.. also different tune will be on the modded chips depending on your car mods etc
yeah checking the AFRs are one thing but dynoing it wont tell you what kind of ign they have wound into it. still considering it's been going for 9 years it's fairly safe to say it's not damaging the car at all... and there is no way of telling what type of tune it was given. every chip saurus make would be different.
Thats exactly what i was thinking, if its been fine for 9years it should be ok, i just wont be turning the boost up at all with this ecu, its currently running 0.5bar from what my greddy gauge is telling me, i may decided to buy a stock ecu in the future just to be on the safe side, at least then i could run a little more boost and not have to worry about it not being "safe".
Anyone have any ideas why both 02 sensors are disconnected?
if they tuned the cruise etc and so forth thy may have turned the 02 feedback off, a properly tuned ecu can return jus as good economy, theonly other optio is that they are shagged and causing the idle to stumble etc..
i quite recently had a V-spec GTR in with a Mines chipped ecu and it was tuned 99% perfect... i was floored as many ive had over the years seemed to just have bulk loaded maps but this thing pulled 260+kw off the bat and had the timing map done spot on.... the only issue was it was a bit rich from 5500 to redline 10.8 so i leaned it off up top and it made the similar peak (about 3-6 more) but at redline made 10rwkw more and a bit more torque.
the limiter was alo set at 8800 :blush:
other than that it was possibly the best "chipped" ecu id ever seen. I ended up not charging for a tune and only a touch up.
NIZMO_FREEK go to someone who remaps facory ECU's, that way they can view the BIN file and compare it to ones thay have done and to the std BIN file. NISTUNE and DATASCAN can view these bin files.
Edited by URAS
i quite recently had a V-spec GTR in with a Mines chipped ecu and it was tuned 99% perfect... i was floored as many ive had over the years seemed to just have bulk loaded maps but this thing pulled 260+kw off the bat and had the timing map done spot on.... the only issue was it was a bit rich from 5500 to redline 10.8 so i leaned it off up top and it made the same peak but at redline made 10rwkw more and a bit more torque.
Thanks for the advice, the only people that remap factory ecu's are a long long drive away from me so i dont think i will be doing that, might just possibly take it for a dyno run and see what the a/f ratios are at the moment, im kinda leaning towards buying a stock ecu at the moment just to be 100% sure its running safe, do you think this would be a worthwhile idea? or would i be wasting me time.
However the car does go very very well how it is at the moment, better than i expected it to go even thought its only on 0.5bar, im a bit hesitant to turn the boost up at all with this ecu though, just to be on the safe side i think i will leave the boost were it is now untill or if i decide to get a stock ecu.
Cheers
im happy to have a look at the bin's if you can send it over.
take the offer!! it's a 10 min job to remove ecu. pop it in an express post satchel with a self addressed one inside and your in business. that way you'll know where you're at, and if it has a stupid high rev limit as many japanese chips do then you can get it set to something sensible (ie under 8,000).
Thanks for the offer :D , might take you up on that sometime soon, will get in contact with you if i decided to.
Cheers mate
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
