Proximity Motorsport Posted January 5, 2009 Share Posted January 5, 2009 Hey, pulled off rocker covers to get painted and found my cams are rusty. Car hasnt been running for about 6 months... any idea if this is okay or not? cheers Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/ Share on other sites More sharing options...
TokyoTaxi Posted January 5, 2009 Share Posted January 5, 2009 That is "NOT" going to be OK Bypass the re-grind and either get some new or 2nd hand ones IMO. Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348038 Share on other sites More sharing options...
Proximity Motorsport Posted January 5, 2009 Author Share Posted January 5, 2009 can i get a confirmation on that by some more people?? Is that because the rough surface will cause premature wear on the valves and possibly cams? Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348060 Share on other sites More sharing options...
2rismo Posted January 5, 2009 Share Posted January 5, 2009 My non-rusty great-condition standard ECR33 RB25DET cams are for sale for $200. You should NOT use those cams. Where does the rust go once it wears off? Into your engine. All bad. Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348082 Share on other sites More sharing options...
DRD-00F Posted January 5, 2009 Share Posted January 5, 2009 DEFINATELY not good. Cams are an instrument of precision, you don't want any weaknesses. You can probably buy some non-rusted second hand ones out of a car being stripped on the forums, or buy some pon cams... but you do NOT want to start the car with that! Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348075 Share on other sites More sharing options...
Proximity Motorsport Posted January 5, 2009 Author Share Posted January 5, 2009 just rang my local tuner and he said to pull them out, and give them a hit on wire wheel buff or with some 800 grit wet n dry. Anyone have any objections to this? Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348098 Share on other sites More sharing options...
Travis Trayhern Posted January 5, 2009 Share Posted January 5, 2009 yeh mate got an easyer option lol, it will only be surface rust just go get some wire wool and clean them up no biggy but put some cheap oil in it and oil filter run the car then drop the oil and replace it it will be right. Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348168 Share on other sites More sharing options...
Travis Trayhern Posted January 5, 2009 Share Posted January 5, 2009 yeh mate got an easyer option lol, it will only be surface rust just go get some wire wool and clean them up no biggy but put some cheap oil in it and oil filter run the car then drop the oil and replace it it will be right. hangon just looked at the pic abit closer lol might have an issue on ya hands try clean them best ya can but if there are any indentation left on the lobs after clean just throw them out and get some others. Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348174 Share on other sites More sharing options...
Proximity Motorsport Posted January 5, 2009 Author Share Posted January 5, 2009 hangon just looked at the pic abit closer lol might have an issue on ya hands try clean them best ya can but if there are any indentation left on the lobs after clean just throw them out and get some others. Okay just spoke to a reputable shop down south in brisbane and they have told me the same thing as my tuner and this young man have. Gotta try clean them, and if its got any pitting at all, throw away, as the case hardening will be affected. cheers Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348181 Share on other sites More sharing options...
DRD-00F Posted January 5, 2009 Share Posted January 5, 2009 You can probably pick up a second hand set for sweet f**k all, means you don't have to scrub away at it either. I wouldn't trust it, but that's just me I spose Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348220 Share on other sites More sharing options...
DAN00H Posted January 5, 2009 Share Posted January 5, 2009 it's only surface rust from what I can see. you can get rid of that, but you need to remove the cams to do it properly. if you are not confident using fine grade emery cloth, then you could take it to a shop. oh - if using a wire wheel, ensure it is brass... Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348252 Share on other sites More sharing options...
Proximity Motorsport Posted January 5, 2009 Author Share Posted January 5, 2009 for those of you who were interested to see how i went... i used a scourer, one of those green plastic wool pads for scrubbing dishes in the kitchen, and some penetrene and within 10 minutes had them clean. Then i poured some engine oil over the tops of them. Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348265 Share on other sites More sharing options...
DRD-00F Posted January 5, 2009 Share Posted January 5, 2009 Hmm... looks alright... spose I'm just a girl then Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348353 Share on other sites More sharing options...
2rismo Posted January 5, 2009 Share Posted January 5, 2009 So you did it in the car then? Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348386 Share on other sites More sharing options...
JAS-25T Posted January 5, 2009 Share Posted January 5, 2009 and all those bits went straight into the motor. lovely. Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348466 Share on other sites More sharing options...
Proximity Motorsport Posted January 5, 2009 Author Share Posted January 5, 2009 no im not a idiot. I used a damp cloth and it stuck to that. You can critisise me all you like but you obviously werent here to see how i did it, and you did not see how the rust came off. There is definately no foreign bits in the motor Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348515 Share on other sites More sharing options...
tridentt150v Posted January 5, 2009 Share Posted January 5, 2009 Actually, some micro porosity isn't a bad thing - maybe the rust gave you that - OK I'm joking. Some tune shops phosphorise your cam lobes so that they have micro pits in them. This is supposed to be good for oil retention and cold starts. If you did them on the car, even iif your really careful, I'd still change the oil and filter after a flush or two. Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348612 Share on other sites More sharing options...
grem Posted January 5, 2009 Share Posted January 5, 2009 i'd probably have not wasted the money on painted rocker covers and spent it on some shiny new poncams, but thats just me. Link to comment https://www.sau.com.au/forums/topic/251115-pulled-off-rocker-covers/#findComment-4348906 Share on other sites More sharing options...
