DEFINATELY not good.
Cams are an instrument of precision, you don't want any weaknesses. You can probably buy some non-rusted second hand ones out of a car being stripped on the forums, or buy some pon cams... but you do NOT want to start the car with that!
just rang my local tuner and he said to pull them out, and give them a hit on wire wheel buff or with some 800 grit wet n dry. Anyone have any objections to this?
yeh mate got an easyer option lol, it will only be surface rust just go get some wire wool and clean them up no biggy but put some cheap oil in it and oil filter run the car then drop the oil and replace it it will be right.
hangon just looked at the pic abit closer lol might have an issue on ya hands try clean them best ya can but if there are any indentation left on the lobs after clean just throw them out and get some others.
Okay just spoke to a reputable shop down south in brisbane and they have told me the same thing as my tuner and this young man have. Gotta try clean them, and if its got any pitting at all, throw away, as the case hardening will be affected.
cheers
for those of you who were interested to see how i went... i used a scourer, one of those green plastic wool pads for scrubbing dishes in the kitchen, and some penetrene and within 10 minutes had them clean. Then i poured some engine oil over the tops of them.
no im not a idiot. I used a damp cloth and it stuck to that. You can critisise me all you like but you obviously werent here to see how i did it, and you did not see how the rust came off. There is definately no foreign bits in the motor
Actually, some micro porosity isn't a bad thing - maybe the rust gave you that - OK I'm joking.
Some tune shops phosphorise your cam lobes so that they have micro pits in them. This is supposed to be good for oil retention and cold starts.
If you did them on the car, even iif your really careful, I'd still change the oil and filter after a flush or two.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
