  • Replies 90
Posted Images
the sigma 10-20 is a DC lens (hence why its part of the name)
sigma DC lenses are made for APS-C size sensors (ie crop bodies)
canon EF-S lenses are made for APS-C size sensors (ie crop bodies)
so yeah the 10-20 IS a EF-S "style" lens (ie made for crop bodies)
(they fact that it looks shit should give you an idea its not made to work with it lol)
edit: ps. wiki refs: sigma, APS-C
and for the record - im not saying "omg dont do it its gonna break your camera"
i dont even know what body you're using
was just a warning for if you didn't know
"apparently some lenses designed for APS-C sensors when fitted to some FF bodies
can cause damage"
Played with my friends 5d mark 2 just before i left London the other day :D Such an awesome camera and with an 24-70L lens it was damn good!!
The quality from the camera+lens= WOW!!!
Bought a 430ex2 yesterday so got a new toy now!!
sorry i haven't been around for a while...needed a break from net and skylines...
so i went and bought this.....
then spent xmas sanding back for new coat....
plus deleting rear handles and all locks and rust etc.....
then paint and some pinstripes and VOILA!!!
still needs some bits etc, clean out the engine bay and whack in some doof
but it'll do for a while!
so the poor 31 will have to take a backseat for a while :P
Edited by dodgsun
haha 4 of us at work decided to have a monthly compition - using the same topic as the Overclockers Australia - this month's was 'fruit and veg'
so took a few crappy pics (as seen here) and then decided to do something a bit more creative so yeah, girl friend made the one in the background and I made the other one :P
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
