Got offered a DR 30 R200 LSD today, $1200. So can someone tell me the specs of this item?
Are they a longnose or short nose? Are they IRS like my R180? What ratio could I expect? and would it be a hassle changing over as I'm really wanting to just plain swap it over?
https://www.sau.com.au/forums/topic/251233-dr30-r200/
$400 for an R200 LSD longnose from a DR30 is a bargain mate, and I'm pretty sure the 31 IRS is the shortnose anyway. From memory the longnose R200 into your car passingewe should be a straight bolt in including axles.
https://www.sau.com.au/forums/topic/251233-dr30-r200/#findComment-4356381
The R200's in the DR30/31 are all long nose specials only difference between the two diffs is the half shafts being thicker on the 31. If you can get R200 LONG NOSE diffs for $400 clams snap em up cause they'll only sell for more!! R200 SHORT NOSE sell for bugger all because they're common as!
https://www.sau.com.au/forums/topic/251233-dr30-r200/#findComment-4356510
Can put my hands on 2 3.9 ratios, and a 4.1 ratio tomorrow.$400 each
R200s aren't that special.
Well, not $1200 special anyway.
Hooks
not that special ? wats special a 9 inch? ba, have fun tryn build a tough one of them 4 under $1200 be lucky to get a good centre for that ..
https://www.sau.com.au/forums/topic/251233-dr30-r200/#findComment-4356535
They are way bigger then an r180.
You will need the r200 shafts and moustache bar.
Then depends on the flange for the tailshaft too.
If you shop around you may find a bargain.
I got one for $290. With the bigger crown wheel bolts too.
Edited by skybt1
https://www.sau.com.au/forums/topic/251233-dr30-r200/#findComment-4357267
All 3 are R200 mechanical lsd's. Prolly a little loose, take em to a good diff specialist and get em tightened up.
R200s are great diffs.
What I meant was there is no shortage of them.
Lots O cars had em.
280/300zx's, HR31's, DR30's
The zed ones come with a really cool alloy finned backplate.
just got to do a little searching at the wreckers.
Hooks
https://www.sau.com.au/forums/topic/251233-dr30-r200/#findComment-4358056
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
