hey guys
I was looking around the net and stumbled on this photoshopped pic
While yes I know it's a photoshopped pic of the R35 GTR...Could you imagine a Stagea with R35 GTR Running gears looking like an R35 or make some changes (as in remove the stovetop tail lights)?
Although calling it a Stagea 380RS doesn't have a nice ring to it
One can only dream
Edited by BigDirtyJase
https://www.sau.com.au/forums/topic/251320-new-stagea/
i'm looking at the point of what changes could you make to make it more it's own car not just a GT-R Wagon...make it more Stagea so it's own car. One thing I can see...I don't know about the tailgate window...it's fairly small...and keeping the GT-R rear end just doesn't suit a wagon
but yeah the photoshop job is pretty good
https://www.sau.com.au/forums/topic/251320-new-stagea/#findComment-4351151
first off nissan wont let the GTR badge on a wagon, they said once before the Autech 260rs was made, that the GTR badge is for racing cars only wagon does not comply a racing car. anywho
the rear end needs a bit of work, be hard to do tho, stove top's gotta go, so does the Renult curvy ass,
https://www.sau.com.au/forums/topic/251320-new-stagea/#findComment-4351190
Very neat photoshop work but I don't think I like it that tail looks a bit annoying (to be true ,it looks like the ugly ssangyong 4wd :D )but hope ,this pic makes nissan think about it and start a new Stagea project :laugh:
https://www.sau.com.au/forums/topic/251320-new-stagea/#findComment-4352215
That is some pretty skilled Photoshopping! Your work TJ? :laugh:
Yes it looks ugly, but I couldn't care less if I had a wagon with similar lines and the same running gear as the R35 GTR
I honestly don't think I could stop giggling like a school girl if I owned something like that!
heh, would give the dog's stabilizers an even harder workout than they already get!!!
https://www.sau.com.au/forums/topic/251320-new-stagea/#findComment-4352302
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
