hi guys thought i might put this on here because it is doin my head in its seems to be lacking alot of power , before it did this it had lots of power pushing u back in ur seat ,but now its nothing like it i have gone all over the car checking if everything is conected and stuff but cant find out whats making it lose power as u accelerate , so if anyone could please help me out would really appreciate it ,thanks
https://www.sau.com.au/forums/topic/251325-lacking-power/
i will do mate thanks but the thing is that it still boosts up lol ,like its has heaps of boost but no grunt behind it , like u driving along in third or four and plant it lags like revs go down slightly and then slowly goes back, but not as a qiuck and responsive like it use to be?and i put a full tank in it and when i have been driving it. the fuel in now down to a quater of a tank and only have done 180km on the tank, i think its somewhere in the eletrontics somewhere,in my thinking it might be getting to much fuel ??? any other problems it might be?? :)
https://www.sau.com.au/forums/topic/251325-lacking-power/#findComment-4355709
arghh this is happening to me too!!! sorry to hijack mate but my car was lagging bad today too.. yesterday i cleaned out my AAC valve to sort out some idle issues i had.. and halfway to the city today the car starts to lag pretty much exactly as you described it.. and the idle is rough and lumpy.
any ideas? no mods really, as i said all i did yesterday was remove my AAC valve to clean it. pretty sure i put everything back on properly.
https://www.sau.com.au/forums/topic/251325-lacking-power/#findComment-4358288
similiar problem to me,
car lags a bit, and i had a really terrible idle.
sometimes car would stall if i take a corner too slow,
changed spark plugs, helped the idle 10%
cleaned aac, helped antoher 10%
changed back to stock bov, from atmo, fixed the whole idle problem nearly completely.
Only issues i have, is
cold start idle, really lumpy
but once i drive aaround the block
it idles fine,
car still lags a bit tho?
https://www.sau.com.au/forums/topic/251325-lacking-power/#findComment-4359447
well thats good to hear mate ur car is goin all rite but mine is still doin in my head im takin it down to a dyno place so they can tell me wats wrong wit it i think its running really rich other words alot of fuel that dont need to be in the engine lol
but no blck smoke tho
https://www.sau.com.au/forums/topic/251325-lacking-power/#findComment-4359982
ok so last night the same shit happened again!! it seems like every 2nd or 3rd time i start it up.. it will begin to idle badly and struggle to make boost. then the next drive it runs perfectly! does anyone have any ideas what could be causing this?
cheers
https://www.sau.com.au/forums/topic/251325-lacking-power/#findComment-4360455
cheers
https://www.sau.com.au/forums/topic/251325-lacking-power/#findComment-4360456
hey yea mine is still doing it but i think i somethin to do wit the computer or the wireing to it coz, i put my computer out and took the plastic cover off where the wires go and just pushed them in to make sure they are making contact, that seem to work for abit so i took it for a spin and then seemed fine , and i was rapped about it and then is started doing it again im going to go over the hole earths wires and everything else to make sure that everything is making contact , if any one else has any better ideas let us know thanks !!!
https://www.sau.com.au/forums/topic/251325-lacking-power/#findComment-4362568
hey guy i went to the autoalic 2day and they found out y i was losing power , turns out that the nock sensor pug was playing up, and now go better , something that simply stuffs up everying lmao thanks for everyones help on this topic have a good one :)
https://www.sau.com.au/forums/topic/251325-lacking-power/#findComment-4379110
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
