Okay guys and girls, its Adelaide's turn. After 2 stunning efforts by Cazz (GTS145) and the committee from Classic Skylines Australia for organising 2 awesome Skyline Nationals in 06 and 08, its time for it to hit the road, and its landing here in adelaide
At this stage it will retain the standard format (until we start working thru things)
Sign in day Friday
Track Day Saturday
Show and Shine Sunday
Going to try and get Wrigley Reserve at Glenelg for the show and shine (this is to be checked on etc) and Mallala for the track day (again, pending on checking it out)
At this point we're looking at the end of july (as thats the traditional time and it tees in with the 7th Skyline Day celebrations all us 31 peeps do) but if theres ideas for a better time of the year we're all ears
Tune into this thread for updates, as we also want volunteers to be on the organising committee. Before volunteering for the committee, make sure you think about the time committment this will take too
https://www.sau.com.au/forums/topic/251346-skyline-nationals-2010/
  • Replies 181
wouldnt it be better to have the show and shine on the saturday and the track day on the sunday?
Definently the track day before the show and shine. That way you know which cars are worth checking out and which ones are just poser mobiles.
Edited by DR JOSH
we're still working on the finer details. last year's nationals (due to a mix up by winton raceway) we had to go to the saturday instead, and i feel that worked well in some respects (especially for those travelling from interstate)
but in some respects i can see what you guys mean, track day sunday would work a treat too
yeah but if i want to take my car out on the track.........and something happens that means she will be f****d for the show and shine...........
but in the end whatever...........
Track damage/broken parts = mega respect points ;)
If it's July your chances of rain will be fairly high. You may want to look at an indoor venue...
PM me if you want some advice regarding venues, or a contact at Holdfast Council for Wigley.
Edited by Iron Chef
no dramas kristian, will pass the helpful information onto the committee, and will drop ya a pm as well mate ;)
  • 1 month later...
CLASSIC SKYLINES AUSTRALIA SKYLINE NATIONALS SA OFFICIAL DATES HAVE BEEN SET:
FRIDAY 10TH - MONDAY 13TH SEPTEMBER 2010
SHOW AND SHINE IS BOOKED FOR THE SATURDAY THE 11TH
Watch This Space for more
  • 1 month later...
I'll well and truly have the manual conversion done for the Stagea, as well as the brake upgrade. Show what the Stagea can do around the track :sick:
I know I sure as hell won't get the 1m17s I can get on my bikes, but I'd love to be in the 20s somewhere ... I know the track well :)
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
