Excellent, should have the new car all sorted well and truly by then :) ! At least being in October we are guranteed better weather!
check post above mate, September 10>
I wonder what the 34 will have by then...so many plans, so many options, so little disposable income... and I just found this emoticon :win: :)
  • Replies 181
Excellent, should have the new car all sorted well and truly by then :P ! At least being in October we are guranteed better weather!
yeah, check the date again james LOL
edit
nato beat me to it LOL. speaking of which, we should get hookups thru work hey :)
  • 4 weeks later...
Cant wait for this, hopefully will be bringing the JDR33M car which comes out next week, the JDMCOP r34, possibly for the roadtrip will have sojucy 180 and the tekken rx7 along for the ride as well...
Most likely Melb Autosalon will be in October prior to final battle in sydney which is like first week of november...so if this is september probably best time, but still possible showers
Ok Guys and Girls!
Nationals & Mallala Pricing
(Application forms and Sup Regs will be up soon)
Nationals entry only (No Track Day Entry included in this price)
Cost: $75
This includes
- Nationals Shirt
- Nationals Cap
- Entry to the show and shine
- Spectator entry to Mallala
__________________________________________________________
Mallala Pricing Track Day Only
No Nationals stuff included in this price
Early Bird pricing applies to this event till the 17th May 2010!
Early Bird: $145
After May 17th: $180
If you want both nationals and Track day you will be up for
$75 + $145
$220.
I will confirm if there is a special price for those who do both. So Stand By
sweet as andrew, will be good to see ya beast in action. going to be a great turnout if we keep these numbers happening :D
stickers are here too, marc only has 50 though
Edited by Matty 31
  • 1 month later...
entry forms should be available very soon (heres hoping)
for those who want in on the track events, dont delay once the forms are available, can guarantee the slots will fill quickly
thats 1 way to rezero the odometer in your car :)
I bought the car to drive it, not just wank over... Plus it has only recently hit the 100,000k mark so its relatively fresh. Also I promised myself that when it got upto 200,00k I would rip out the 25 and throw in a 26. So it's all good as it all feeds my ultimate goal.
Blinky
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
    • Your profile doesn't say where you are, but you can get your current turbo rebuilt by any competent turbo shop, places like Precision Turbos or GCG They can replace the core with a modern ball bearing unit and should be able to source same or slightly larger wheels to fit in you housing. Note if you change the core you may need new oil and water lines too
