  • Replies 447
"grooved dimpled (dimpled and slots) gold passivated, more rust resistant"
hi i received my rotors today, not what i ordered.
mine are not slotted
how do we fix this
kind regards james
Hi James,
That image I put on the 1st post of this thread was actually wrong as RDA put up the wrong one on their website. they have fixed it now.
Your grooved & dimpled rotors pattern should look like below. this is the correct one. If it is not let me know what they gave you...
did they give you the plain one?
ok, you posted
Grooved Dimpled (Dimpled & Slots) - Gold Passivated - more rust resistance
and the pic of the rotors were slotted
the two types you had on offer were standard slotted and grooved dimpled slotted
and the price seemed to match
is it possible to replace these with the ones that were advertised
mayby it was just a mistake with the part numbers
so you wanted the gold passivated in straight slots with no dimples?
as far as I know RDA made the grooved dimpled gold passivated in curved & dimples.
the straight slotted ones will come in standard steel, not gold passivated. they did posted the wrong pic on their website when they change the overall website look, which I did ask them why the gold one looks different, and they have now replaced it with the right one, but since the new forum rule not allowing me to edit my posts after certain number of hours I could not replace the pic in the first post anymore.
the part number is correct. Rear R33 non turbo 7692G. The other one, 7692S, will come in 'white' stainless steel colour with straight slots and no dimples. not gold passivated.
what have you currently got at the front - is the curved shape grooves & the dimples causing a 'cosmetic' look issue ?
i just wanted slotted rotors,
i thought the gold passivated, grooved and dimpled rotors you advertised. were slotted
like the pics, but there not
slotted being the holes going through the rotor not the grooves or dimples on the machined face
i dont mind the mistake i just hope it can be fixed,
is it possible to get slotted rotors exchanged for the unslotted rotors i currently have
the rotors with holes going through the rotors is called a drilled rotor, not slotted. but RDA don't do them because they tend to crack under hard use with rapid heating and cooling cycle.
so they only offered (straight) slotted in steel finish, or the grooved & dimpled, which is actually the "grooves" name they were called by are actually curved shape slots. It's just like a marketing 'brand' calling curved slots as grooved, or sometimes they call it groovy.
I could ask but normally 99.99% they won't take returns if there is nothing wrong with the rotors, unless you had it for normal street use (not track use) and the rotors crack, as it will be a warranty return. Will have to ask them sometime tomorrow but I can't promise... as they haven't told me they make the gold passivated in straight shape slots like the standard slotted.
unless you're ok with the standard steel look (no gold anodised)...
just to add to rs73's comments, you REALLY don't want drilled (or also called cross-drilled) on a street car, they WILL crack under heat during street use. Yes the pictures are slightly differently, but at the end of the day, slotted is slotted, they will perform the same (the dimpled gold ones even better), both will allow the gases to escape and to increase the cooling area of the rotor.
I know its not any of my business but I wanted to chuck my 0.2 in.
ah, James. I got it now... It's called vents.
so the answer is no, RDA only have R33 non-turbo with solid rear discs, not vented.
There used to be an old part number RDA7690 but it is no longer available on the market.
and the dimension is a little bit different (hat height is higher and rotor total thickness is double the RDA7692)
so you may have a big problem trying to fit it in with your factory calipers, that is if you can still find RDA7690 around.
sorry for the confusion.
ok then sorry for the hassels.
you seem like a good seller and no-one else has had problems with you, Ive just come undone by those pics a bit misleading. but thats not at ur end.
i should have pm'd this rant
sorry mate
PS: the front R33 non turbo is made in vented rotors... (RDA7691)
not all cars have vented front to rear... my brother in law's Alfa Romeo 147 is an example, vented fronts, and solid rears.
sorry mate
no, that's allright. always try to help. and this information here will also be beneficial for other people who wants to understand some industry terms in brake rotors.
sorry about the pics as well, as I am limited by forum's feature so I am unable to edit some old posts, unless I start another thread which is a bit of a hassle to do.
the groovies should help your brake cooling at the rears, better than just standard slotted, considering as vented rotors wasn't an option in the first place.
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
