  • Replies 447
Glad to hear.
Killabeez, check your pm. Yes S13 rear is available.
Musky, the choice for upgrading the rear or not is totally up to you. I had front slotted on my old R33 Gtst and std rear as well. No problems.
Could I please get a quote for Front slotted + Rear slotted rotors and Green EBC pads all round for a R34 GTT? Ship to Adelaide. Thanks.
gday mate
um ive got an r34 gtt
wondering how much all up to get Grooved Dimpled on the front and standard slotted on the back both with pads will be sent to adelaide, 5108
thanks mate
oh thats a decent price um when will the next groupe buy be after that one mate?
um brakes not really in this months budget
no problems
next group buy some time in early July.
if you go to My Controls, upper RH corner, then on the left sidebar go to Board Settings, make sure the "Disable Personal Messenger" section is set to No.
Setting it to Yes will disable your personal messenger.
if still doesn't work, email me: rsoputro at hotmail dot com
(replace the obvious words above with the proper symbols, you know the drill - spam prevention)
i'll send you a quote soon.
Hey bud, after current pricing on front slotted; and for both plain and slotted for rear rotors. To suit R33 GTS-t. Delivery to 4108.
Cheers
Edited by N-DAWG
Hi, is there anyone online who can tell me in the next 5 minutes how the hell to get the rear rotors off an R34GTT? Otherwise I am taking to it with a slegehammer. I assume the handbrake assembly is inside the top hat and I somehow have to undo that? Please help ASAP. I have the car in 1,000,000 pieces right now and want to get it back together.
release handbrake. handbrake drums might be pressing the inner drum of the rotors, making it too tight to remove.
it can get sticky, from all those age old rust and dirt and grime get stuck in between. use rubber mallet. sledgehammer is a bit extreme... :-)
Yeah I released the handbrake. So there are definitely no other nuts/bolts to remove once the brake caliper is off? Just bash the bit of the disk you can see? Trouble is with the shield around it there is not much room to swing or hit.
Damn - might jack it up as high as it will go and get some leverage on the mallet. Thanks! It doesn't seem to have much movement at all - I take it it will gradually loosen up and come off?
Well I have just finished putting it all back together.
In the end I gave up on the getting the rear rotors off - making the necessary noise at 11pm seems like a bad idea in my neighbourhood.
So, today I did:
- Fitted front RDA slotted/passivated rotors
- Fitted front QFM HPX pads
- Fitted front and rear ADR compliant braided brake lines
- Flushed entire brake system with Motul Dot5 and refilled/bled
- Painted all calipers gold
Phew - 9.5 hours all up.
The result is below
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
    • Not a huge update because still waiting for some fittings for the intake. But I did corner weigh the car, its enough to make a GTR driver cry at 1163kg (race ready except no fuel)  Sorry about the terrible pics but I think they are readable With 70kg driver
