  • Replies 447
Hey Rianto,
How much for EBC reds front and rear for R33 GTST delivered to 2112?
Will attend to your inquiry asap, wife just gave birth to our son 2 hours ago!
RDA group buy 48 order list:
- aleks (payment cleared)
- Malz34 (payment cleared)
- G3TFKD (waiting for payment to clear)
- Roland (waiting for payment to clear)
- WTF-33R (waiting for payment to clear)
RDA group buy 48 order list update:
- G3TFKD (payment cleared)
- Roland (payment cleared)
you can send to email: rsoputro at hotmail dot com (replace 'at' and 'dot')
PM also sent....
- mind_riot (waiting for payment to clear)
Terry's order added to RDA group buy 48 list:
- tteerrrryy (waiting for payment to clear)
hi mate. im chasing a rotor with the following specs
324x22mm 5x114.3 stud pattern and with a 190mm hand brake diameter (or as close to as possible)
hub diameter is 60.1mm but thats not really that essential
thinking the 350z track rotors might be exactly what im after (322x22..)
if u can find a more suitable match - can u please send me a pm with prices and perhaps the offset of the brake shoe mateing surface from the back of the hat.
this is to suit a custom setup on an ma70 supra.
cheers
Edited by DCIEVE
350Z brembo version has 322x22mm at the rear. 324mm is the front, no rears have 324mm, only 322mm if this is what you mean?
The 324mm is for the front and the thickness is 324x30mm
The total hat height for the 350Z rear 322x22mm is 62.5mm (or 40.5mm if you exclude the rotor's thickness) not sure if that is the right offset you want?
However there are no mention about 190mm hand brake diameter.
Let me know if this match the spec that you want. I don't have data on brake shoe mateing surface, sorry.
sorry, did mean 322mm.
i read this on one of your other posts and gave me the impression that some nissan car/version has 190 mm park brake, which is what i require.
17. V35 Skyline / 350Z track brembo: Available in EBC Gold F=GD7122 324mm, R=GD7123 322mm or RDA Gold F=7685G 324mm, R=7689G 322mm
(Fits all V35/350Z 2003-2004 coupes with Brembo Calipers)
18. V35 Skyline / 350Z late model 2005~ update: F=7965G 320mm, R=7966G 308mm (NOTE: V35 need to upgrade rear park-brake drum shoe to 190mm diameter)
pm sent.
Regarding that note, it's because I've sold non-brembo rear rotors & brembo size rear rotors to early V35 without problems.
Apparently they are all straight fit / interchangeable with 350z.
However I had someone finding out the expensive way that the rear 350z late model 308mm rear rotors do not fit because
he had 170mm rear park drum brake. So apparently either:
a) JDM V35 has smaller 170mm park brake from 2005 onwards; or
b) 350z has bigger 190mm park brake from 2005 onwards.
I have no idea which one of that possibility is true.
If a) is true, then it will solve your problems because that means all rotors for 350Z are produced with 190mm rear park brake allowance.
If b) is true, then the rotors you are gonna order will have a clearance only enough for 170mm park brake...
Update - added fat200sx order & all other payments cleared
- WTF-33R (payment cleared)
- mind_riot (payment cleared)
- tteerrrryy (payment cleared)
- fat200sx (payment cleared)
Basho: quote sent..
blyl: check your pm - I need your delivery details to avoid any delays...
- blyl (need delivery detail)
Are the rotors on it came off R32 GTR or are you just using the R32 GTR calipers?
If the rotors are off a R32 GTR, you can measure the front one's diameter across. If it's 297mm (around 30cm) then it's the early models 89-93
If the rotors are 324mm (around 32 1/2 cm) then it's off a 93-94 late V-Spec II model.
Hope that helps...
Hi
Finally got my measurement, it's similar to the early model but I got it in 290mm.
Now I wonder I might only have the R32 caliper so is that mean any r32 early model rotors would fit for my car.
Thanks for your help
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
